Es9j4 timing tensioner advice needed
Results 1 to 3 of 3
    Dec 2010
    423
    Default Es9j4 timing tensioner advice needed
    Doing a timing belt kit / water pump on a es9j4 and have an issue. It had the earlier type tensioner and I have the late one to replace it. Tensioner bolts up with no issues, but the new water pump I have has provisions for the locating pin of an old style tensioner.... This fouls on the tensioner bracket. What I'm wondering, is there a different pump available without the provision for the pivot pin? Do I have the wrong pump? Or is there something else I have overlooked. Thanks.
    Via the aussiefrogs App
    Member PaulRoper's Avatar
    Jan 2003
    50
    I have similar issue here. Ready to change cam belt, but have the old style tensioner. Apparently you just need to cut a corner off the new style one??
    Does anyone know how to set tension on old style tensioner without the magic SEEM gadget?
    Dec 2002
    Menzies Creek
    2,541
    You need to cut a corner off the water pump. I've got one apart at home at the moment, I'll take a picture when I get home in a couple of hours.
    Sent from my C625b using Tapatalk
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
