Radiator Options for 205
Results 1 to 22 of 22
    1000+ Posts pug-life's Avatar
    Geelong
    1,226
    Default Radiator Options for 205
    Hey Froggers.
    Just wondering what radiators people have used for their 205 GTi's /Mi16 conversions also ??
    I read somewhere that nissan have one that is compatible.
    I found some aluminium radiators on Alibaba.com for reasonable price. Yet to hear back exact cost.
    But looks like Valeo ones which are just metal are around the $280 + GST mark.
    Preferably I want something quite slim.
    1,376
    I think the Nissan ones you are referring to is the European Nissen's Brand. Great quality but don't think they are in Oz yet.
    Feb 2013
    Sandringham/Victoria
    465
    Recently fitted a Hella ally core/plastic tank radiator (8MK 376 715-351) from a Sydney based distributor... just over $200.
    It was for a non A/C car so was 3mm thicker and 16 taller, but I made up some new mounting brackets to get the correct height in my Series 2. The extra capacity might be of value if you are going down the bigger HP route. I don't believe they have the A/C model in stock.
    Geelong
    1,226
    Well I have/will have AC at some point. The one I've got in the car at the moment is a Ordonez, but somehow has pin prick leak from something unknown. Its not touching anything that would have caused it so im guessing manufacturing fault. It is slightly thicker than the original one which I split putting the Mi16 in (also Ordonez). Ideally Id like a slightly thinner so there isn't the chance of it hitting the inlet manifold.
    The Valeo ones are both metal. If I can get my hands on an aluminium one that would be ideal.
    So the Nissan ones. What kind of car are they off?
    brisbane
    2,903
    Its Nissen [not Nissan as in the car ] :}
    They sell them for 205's in the UK.....but most are non air con type radiators so be careful with that one. They do sell air con items however they are more expensive.
    EAI in Melbourne had good ones on Ebay a few weeks ago....Magnetti Marelli brand for approx $240 i think.
    jr20516v
    Now:
    Exige SC [modded], 205 Si. 205 GTi , Megane R26 LY , Megane 225 [modded ]
    Previous: Honda EP3 Supercharged , 205 x34 [ including MI16 TURBO, 8v TURBO, CTI, 16V+TB's, 8V+TB's,] Fiat X1-9 X3, Beta coupes x5, Lancia Gamma coupe, GTI-R, Corvette C4, Fiero x5, Alpine GTA turbo, r5 GTT Dimma, 2cv ripple nose, Lotus Elise, 205 Dimma TT, Cliosport 172.x2, Clio rs 200
    Fellow Frogger! 1pugnut's Avatar
    wollongong
    442
    On the 205 that I took you see when you came up, he used a ally one from China.
    It was brought on ebay you might not find it on Australian ebay you may need to do a would wide search.
    Very handy as you can reposintion the outlet's if you need to, and it has worked very well no over heating issues with the S16 convertion
    And it has a working a/c unit
    Regards jamie
    This would be my choice ebay item Number 251378348398
    series 2 405 mi16
    205 si
    series 1 205 gti
    series 3 205 with a gti6 motor project
    1970 404 ute 504 ti motor project
    parts cars 2 205 si's 306 sedan
    2004 206 gti180
    Geelong
    1,226
    Quote Originally Posted by jr20516v View Post
    Yeah I saw these actually. At 32mm thick its probably not a bad option either. The one I have is just a bit think with the surrounds around the radiator. The original one was thinner.
    Quote Originally Posted by 1pugnut View Post
    Regards jamie
    Yeah I don't mind buying form China, but it'd have to be ok. I don't wanna buy a dudd. Getting back to Aus safely would be my other concern.
    He doesn't find much difference in heat transfer being aluminium?
    wollongong
    442
    Quote Originally Posted by pug-life View Post
    You seen the standard of Lindsay's car, he is very particular and he is happy with his .
    It arrived in good condition. But I understand things do get damaged in transit.
    The radiator is very efficient,the cars temp stay pritty consistent in all types of driving.
    series 2 405 mi16
    205 si
    series 1 205 gti
    2004 206 gti180
    1,376
    Not wanting to look stupid, but what is the difference between a Ac and a non Ac radiator? Is the radiator larger for an Ac car?
    brisbane
    2,903
    Mark, i dont know about the size difference however the AC version has the extra inlets and outlet piping holes. They are always more expensive too.
    jr20516v
    Now:
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,441
    My 205 16v still has the original radiator in it. If your radiator leaks (and it is an original copper one) take it to a radiator shop?
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    7,483
    yes, AC and non-AC radiators are different, only in terms of height, not fittings. My recollection is that non-A/C are shorter. Parry bought one and we had to remove the extension bars down the bottom, that tilt the radiator towards the engine, allowing the condensor to sit in front. I've been watching this thread as my 205 was sitting on 98-100 at Eastern Creek two weeks ago. I think it's because BIGRR turned up. The radiator is in perfect condition but I think the extra hp and a very hot day (36+) reached the limit. I was thinking of something custom. Any ideas?
    Geelong
    1,226
    Quote Originally Posted by BIGRR View Post
    Well I put a decent split in the original after not realising the A/C piping that runs down the back was stuck between the radiiator and inlet manifold. I thought had crossed my mind about getting it re-cored, but after the hassle of that it might be just worth while buying a new one. I might investigate that tomorrow anyway.
    Peter mine sits on about 90-100 normally...I think yours is working better than the current one I have.
    Copper would transfer heat better than any aluminium though wouldnt it?
    I'm leaning towards the magneti marelli one on the EAI Ebay page. At 32mm, it will allow for extra mm clearance from the inlet mani. Game of inches (mm in my case)
    Nov 2012
    374
    When I did the gti6 conversion I needed to get some radiator hose extensions made up and got them custom made by PWR. While I was there I asked about a custom radiator for the 205 and they said it would be about $750 IRC. Yep, it's exy, but they make some very fine radiators!
    Fellow Frogger! chez00's Avatar
    567
    Just bought a valeo for my mi16 conversion, see how it goes. I thought in the end I'd rather closer to OEM than aluminium/plastic. Same sort of price as the EAI option.
    1988 205 GTi XU10J4
    2001 406 Monaco 5sp V6
    Geelong
    1,226
    Quote Originally Posted by chez00 View Post
    Yeah I might do the the same. $280 + GST approx? Are the the same radiator as the 205? Just went down to see the radiator fellow, and he said to get mine recored would be quite expensive, also being a two row. He said the Valeo ones are quite good and not too bad of a price.
    567
    Call caravelle - they sold me one cheaper than that but it may have been trade price so I don't want to put words in their mouth.
    1988 205 GTi XU10J4
    Geelong
    1,226
    I just read a F/S thread from a while back. MICAH sold his Valeo one as he required the 309 GTi one, as they are thinner?.
    I'm a little confused with the A/C and NON A/C radiators myself. Of all the radiators ive had the've just had top and bottom hose and the overflow to the bottle. The A/C condenser piping goes over the top and down the back to the compressor and thats about it.
    Whats the thinnest they do? Im leaning towards that magneti one.
    567
    I'm unsure. I'm doing an xu10j4 swap which seem to have less clearance issues than xu9j4. If I need I will just lower the rad mounts the minimum required.
    1988 205 GTi XU10J4
    Feb 2013
    465
    FWIW, here are the specs for the Hella units.
    With A/C 610 x 270 x 33
    Radiator, engine cooling for Peugeot 205 of Hella 8MK 376 716-131 - rexbo.eu
    BEHR HELLA SERVICE 8MK 376 716-131 (8MK376716131) Radiator, engine cooling
    Without A/C 610 x 286 x 36
    Radiator, engine cooling for Peugeot 205 of Hella 8MK 376 715-351 - rexbo.eu
    BEHR HELLA SERVICE 8MK 376 715-351 (8MK376715351) Radiator, engine cooling
    (Note this doesn't have a filler cap on the top, but has a nice accessible captive drain plug)
    EAI are quoting the Magnetic Marelli as 610 x 265 x 32.
    Geelong
    1,226
    Quote Originally Posted by ng850 View Post
    Thanks for the info mate!
    That puts it all in perspective.
    I said there was mm's in it...apparently 3mm. HA!
    It's also very noticeable on my current radiator (ordonez non A/C) the height. The bonnet latch touches the top.
    I think ill invest in the valeo or magneti.
    Thanks everyone for the input!
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    20,553
    I had my original (AC) radiator re-cored. I was told the original was dual core and it was redone in triple core (so I was told). Very tight fit on install but worked fine on standard S1 8v 1900. From memory the cost was around $500 - $600 mark.
    Every day is a good day
