205 camber
Results 1 to 3 of 3
Thread: 205 camber
    1000+ Posts pug-life's Avatar
    Geelong
    1,226
    Default 205 camber
    Hey froggers.
    I recently got a wheel alignment on my 205 after replacing tie rod outers and putting my Koni's back in.
    Passenger Front has about 1 deg of negative camber, but the drivers side is basically at zero. So a degree out if you do the math.
    I know it's not much but, i think you can certainly notice in a left hand bend.
    Is this common?
    And is the only way of fixing it by putting adjustable camber tops on?
    Julian
    NSW
    627
    Loosen the cross member and realign to give 1/2 degree either side
    Adrian Wuillemin
    Geelong
    1,226
    Ahhh right. Thanks Adrian. I'll get that done!
