02 406 - wanted supplier for ignition switch and wiring loom
Results 1 to 2 of 2
    Nov 2011
    47
    Default 02 406 - wanted supplier for ignition switch and wiring loom
    The plastic switch part of my ignition is seized solid but barrel and key are fine. I have seen this loom with the switch on the internet for 26 quid from the uk - anybody know of a supplier? Sounds like a common problem from trying to sort out my climate control fan problem and somebody suggested this. Prefer not to use a secondhand one given problem is common.
    Nov 2011
    47
    Just in case it helps someone else - i went to upullit and got one off a 306 and had different plugs and even slightly different plastic body, but too a risk because the rotating part looked the same. I clipped off the plastic cover and put the round moving part in - checked with multimeter and all works perfectly.
