Lost only key to '94 306 - help
Results 1 to 8 of 8
  • 1 Post By alpine
Thread: Lost only key to '94 306 - help
    Feb 2012
    Ballarat, Vic
    11
    Default Lost only key to '94 306 - help
    Anyone able to give any hints on how to get into my 1994 306? Have no keys and need to get in so I can replace the barrels and locks. I'd prefer to not break a window...
    Oct 2003
    canberra
    856
    If you can get into the boot
    short the fuel flap filler lock wires together and that should activate the central locking and unlock the doors
    FedGrapes likes this.
    Fellow Frogger! FedGrapes's Avatar
    Aug 2011
    Perth, WA
    835
    Thanks for the tip alpine, that might come in handy one day!
    Edit: When I locked the keys in the 504, I used a wooden wedge with a tea towel to prevent scratching the paint. This wedged the door open enough to use a coat hanger and unlock the door.
    Also, RAC/NRMA should also be able to get into the vehicle. They use and air wedge which is a bag that you slide between the door and car body, and then inflate. Same as the wooden wedge, but a lot nicer to your car.
    Nov 2011
    47
    last night in my hunt to solve my problem i saw on youtube that their were a number of videos on how to pick a lock, some might have even been Peugeot....... but no time to watch to see how useful. Just a suggestion and it is surprising how much is on there, including how to get the ingition barrel out of a 406, that i modified to get an ignition barrel out with the key stuck in the on position!
    Fellow Frogger! julian b's Avatar
    Aug 2011
    hawthorn melbourne
    482
    I would suggest calling the RACV .They would know all the tricks
    Melbourne, Australia
    24
    If you don't have any keys, you don't have a transponder and the engine immobiliser will prevent you from starting the car.
    Feb 2012
    Ballarat, Vic
    11
    I broke in and got the car towed home.
    I'm buying a complete set of keys, new locks, ignition barrel and infra-red sensor from a fellow aussiefrogs member. I'll swap it all out and should be okay.
    Being a 1994 N3 XT, I don't think there is any transponder etc in the key... but I may be wrong. We;ll see I suppose.
    Thanks all.
    Don't remind me!
    16,609
    There is no transponder; it is IR-paired remote locking and that's about it (unless fitted with an immobiliser keypad).
