Aluminium Rocker Cover
Results 1 to 9 of 9
    Oct 2005
    Panorama Heights, Devonport, Tasmania
    115
    Default Aluminium Rocker Cover
    What is the best way of cleaning a very dull Aluminium Rocker cover on a '97 306?
    8,954
    Truck places will sell aluminium body cleaner containing hydrofluoric acid. Check up safety sheets before even buying; this stuff is extremely nasty.
    (PS) This sort of stuff - http://www.septone.com.au/msds/ATA1.htm. Works, but not nice at all.
    1000+ Posts michaelr's Avatar
    1,393
    A cheap sand blaster loaded with baking powder gives a nice warm shine. Good for carburettors too and no grit residue, just wash with water.
    Michael
    Member, Citroen Car Club NSW
    Jul 2013
    southampton Ontario Canada
    89
    My back ground is high voltage electrical and we use to dip our alunimun cables in a bath of hot water and lye ! the result was a clean finish You can try out the finish on a aluminum pop / beer can for a test . The only thing that sometimes interfers with getting it to work properly is if it has a painted clear finish which would have to be stripped down with a good chemical paint stripper. Word of caution the gases produced coming off the cleaning process is Hydrogen. ( no sparks or open flames close by )
    Manic gt
    SWOTR
    3,634
    If the blurb in Wikipedia is accurate then I wouldn't go anywhere near hydroflouric acid. According to wiki this stuff isn't just nasty, it's lethal - "By interfering with body calcium metabolism, the concentrated acid may also cause systemic toxicity and eventual cardiac arrest and fatality, after contact with as little as 160 cm2 (25 square inches) of skin."
    Have a read of other extremely dangerous aspects of this stuff.
    It's how I roll...Brisbane
    33,391
    Metal polish and elbow grease is the best method.
    7,483
    This is a good read by a pro. You'll need to be a member to see the pics however.
    http://forum.205gtidrivers.com/index...pic=152032&hl=
    Polishing Cam Cover Progress - General Car Chat - 205GTIDrivers.com
    8,954
    I did say the acid was nasty, but none the less, the cleaner is readily available and widely used, eg Septone Ali Brite Aluminium Cleaner - 1 Litre - Supercheap Auto Australia
    1000+ Posts bluey504's Avatar
    Dandenong Vic
    1,256
    Just to add to the warning status. Have a quick read of the "CX oil o-ring" thread.(Can one of the wunderkinds do this as I really don't know how.) I point out the dangers of exposing Viton O-rings to flame but Septone remove the need for heat and make it easy to harm/kill yourself. Then again when I've been involved in cleaning out very old garages and sheds the toxic stuff that came out would make your head spin, fall off and vaporise in a puff of green/purple smoke with a lingering odour. Brendan.
