Throttle bodies and vacuum line for brake servo
Results 1 to 3 of 3
    1,376
    Default Throttle bodies and vacuum line for brake servo
    After the installation of ITB's ,what then supplies a vacuum for the brake servo? Do you connect 4 separate small vacuum lines and "T" them all together into a bigger hose for the servo?
    All of the installs I see show no vacuum apart from maybe a vacuum gauge.
    7,483
    That's certainly one way. A vacuum manifold underneath, with an pipe to each runner. JeffR has his welded in. Mine has four small flexible tubes which connect to a larger solid pipe. You often see installations were just one manifold runner is used as well. It all depends on how much time you have to build up vacuum between pumps. Another factor is the ECU. If you're mapping fuel and ignition by TPS then you don't need vacuum. If more exotic, and mapping fuel by TPS and ignition by MAP, then you need the vacuum manifold. Another solution is to use an S16 vacuum pump on the end of the inlet cam. I like JeffR's manifold as it's permanent, out of the way and nothing can come loose.
    1000+ Posts pgti6's Avatar
    May 2001
    1,618
    Depends whether you want to go to the effort of removing the throttle bodies & have something welded in to your manifold for a permanent solution.
    This is how I went about it. Have a look at Post 75-
    [trackday_prep] 405 Mi16 Track Car - Page 4 - Trackday & Race/Rally Prep - 205GTIDrivers.com
    Lap times-
    Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
