metal clanging noise
Results 1 to 10 of 10
    nJm
    nJm is offline
    Guru nJm's Avatar
    Jan 2002
    Melbourne, Australia
    2,930
    For a while there has been a light metal on metal clanging noise coming from the front left corner of my car. It used to just happen while cornering or going over bumps, however now it just happens any time, including when I slam shut a door. I thought it might have been the wheel trim on my steel wheels vibrating against the rim, but it is still there after taking them off.
    I can only describe it as sounding like two metal coathangers (but heavier and louder) being banged together. I tried wiggling everything in the wheel arch but they don't make noise. Any clues? It's driving me insane!
    Nick
    1983 Peugeot 505 GR
    Guru davemcbean's Avatar
    Apr 2001
    Camden NSW & Selwyn NZ
    2,334
    My 505 made a similar noise. It turned out that the front left strut bump stop had rotted away, leaving only the metal ring (from inside the rubber) to jump up and down. This sits inside the front spring so if this is the problem you should be able to compare the front and left bump stops and feel if one is loose, or see if it's rotten.
    Dave
    <small>[ 26 May 2003, 10:13 AM: Message edited by: davemcbean ]</small>
    NZ Fleet
    1976 504 Ti
    1984 205 GT twin carb
    1991 205 SI 1.6GTI motor
    1994 106 Xsi
    1996 Mondeo V6
    Aus Fleet
    1955 203C
    nJm
    nJm is offline
    Guru nJm's Avatar
    Jan 2002
    2,930
    Thanks Dave, that seems to be it.
    When my car is jacked up, the driver's side wheel droops down a bit futher than the passenger side one. Is this related?
    *it is the passenger side where the noise comes from though.
    Nick
    1983 Peugeot 505 GR
    9,223
    Different brand strut inserts? Maybe an insert in the left and original bits in the right?
    Fellow Frogger! aquinian's Avatar
    WA
    604
    nJm:
    Sounds like Dave might have identified it. The other common one is the front of the trailing links (is that what they are called on the front end?) where they pass through those large bushes to the front, where they are retained by a large nylock nut. The bushes wear out and the links move back and forth as you brake and accelerate. The sound is more of a "clunk" than a bang, although it probably depends on how much rubber/neoprene material remains, and how hard you stop or accelerate.
    John Lane.
    Current: 406 Coupe, 504 Sedan
    Previous: 306XSi, 205GTi, 206Gti, 505 V6, 505 Wagon, 504 Sedan, 504 Wagon, 306Gti6, 306XT, 205Si, Citroen XM, Citroen Xantia
    nJm
    nJm is offline
    Guru nJm's Avatar
    Jan 2002
    2,930
    Well the noise occurs now (didn't before) when sitting at idle (whole car vibrates due to worn engine mounts), when I slam the driver's door shut, and when there is suspension movement.
    Is it easy to fix Dave? I haven't looked it up in the haynes manual yet.
    Nick
    1983 Peugeot 505 GR
    Nov 2001
    1,640
    Yes. This is a very common issue with older Pugs. One sure4 sign is a pulsating sensation when braking (especially just as you are coming to a complete stop) that many people assume must be warped disks.
    Can you actually isolate the location of the sound clearly if you get someone else to slam the door, Nick?
    (they are called "radius arms", by the way, Aquinian)
    Rod
    <small>[ 27 May 2003, 09:48 AM: Message edited by: Rod Hagen ]</small>
    Rod's Home Page
    Rod's car page
    nJm
    nJm is offline
    Guru nJm's Avatar
    Jan 2002
    2,930
    That is interesting Rod. I haven't noticed it for a while but it does tend to pulsate a bit under braking (only noticable at freeway speeds). As with all strange issues in these cars there are always more than one likely reason . I'll start having a poke around.
    I had all my castor bushes and tierod ends done about 4 months ago. Are they related at all to radius arms?
    As for where the noise is coming from - it sounds like it is coming from near the top of the suspension on the front left, although I'm not certain. I've tried hitting the top of the strut and it won't make the noise .
    Nick
    1983 Peugeot 505 GR
    9,223
    Indeed, it is the 'caster bushes' about which he speaks.
    Nov 2001
    1,640
    Dave's diagnosis is probably right, Nick, but it certainly doesn't hurt to take a look. Its often hard to tell where a sound comes from when you are inside the vehicle (or even oustside for that matter!) A stethoscope, or even a piece of dowling rod or metal pipe that you can stick on the suspected component (with the other end to your ear) can work wonders.
    Rod
    Rod's Home Page
    Rod's car page
