406 V6 Quaife differential group buy
Results 1 to 15 of 15
    Fellow Frogger! Brett's Avatar
    Nov 2001
    617
    Default 406 V6 Quaife differential group buy
    Is anyone interested in a group buy for a Quaife differential to suit a 406 V6 manual BL gearbox?
    Their minimum order quantity is 10
    Brett
    Via the aussiefrogs App
    Bathurst______2 57.22 Sandown_______1 35.29
    Mallala_______1 22.90 Phillip Island____1 56.41
    Winton_______1.43.90 Collingrove_______38.08
    The Bend_____2 21.96
    https://www.facebook.com/FrogstompRacing/
    http://www.harlandeng.com.au
    Oct 2012
    Perth, WA
    10
    I'd be interested if it were for the ML5T. Is this a Limited Slip Diff?
    '00 Peugeot 406 Coupe 3.0 (ES9J4S)
    Fellow Frogger! Rally's Avatar
    Pearl Beach NSW
    547
    I might be interested if the price is right , come on down with the cost.
    Are there two types of manual box fitted to the 406 V6 , how does one tell the differance?
    Peugeot 504 Rally car V6
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    Peugeot 406 SV 5 speed
    Citroen DS23 EFi Safari
    Toyota Land Criuser V8 Super charged ( to tow the rally car )
    Rally with www.AMSAG.com.au
    9,267
    If you can mix and match I could possibly be interested in a BE3 one, depends on the price.
    Palmside in NZ were happy to do this last time, we got BE3 and 505 diffs in the order. Is this where you are getting them from?
    Quaife UK will refer you to them in any case.
    Edit: on rereading seems like they may need to put through a batch of 10, bit like the 505 diffs, so my order may not help at least with the initial order.
    Graham
    Dec 2002
    Menzies Creek
    2,541
    Also interested depending on cost. And assuming it is in fact for the ML series of gearboxes. Never heard of a BL.
    I believe the quaife ATB for the V6 was actually initially made for the Boxer van - QDF6H?
    Have you been on Bienvenue sur le site du coupé 406 or www.406coupeclub.org to help bump up your numbers?
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    Nov 2001
    617
    Sorry I meant ML.
    Yes, I was looking at the Quaife to suit the boxer.
    A Finish website indicates machining of gearbox casing and reinforcing required to fit though.
    10 appears to be the minimum order quantity
    I was gauging local numbers before checking overseas.
    I was going to check with other differential manufactures about a custom build once I had an approximate number.
    Nov 2001
    617
    Looking at a budget price of $1500ish for the ML5 LSD subject to exchange rate, final cost etc
    Are you still interested?
    Thanks,
    Brett
    Dec 2002
    Menzies Creek
    2,541
    Quote Originally Posted by Brett View Post
    Thanks,
    Brett
    Possibly - what sort of diff are we talking here? Is it a Quaife-style Torsen or the like, or a plate type diff? If so, would it need machining like the the Quaife for the boxer would, or would it be something that would drop straight in?
    Scotty
    Nov 2001
    617
    It would be a plate LSD.
    Hopefully it will be a straight drop in. I won't be able to confirm this till design is finished.
    A gearbox has been sourced in the UK, where the fabrication will take place.
    It would be internally similar to those below, as they will try and use an existing plate/spring arrangement.
    Oct 2013
    Auckland, New Zealand
    9
    Not sure if you saw my post on 406oc.co.uk but I am definitely keen on one. I have put out a quick word on fastfrogs.co.nz to see if I can boost numbers but its not looking too bright :/
    Nov 2001
    617
    Sorry, I hadn't seen it.
    I think I need to repost in a different sub forum on 306GTi as everyone says people are interested on there but I haven't got any replies as yet.
    Thanks,
    Brett
    Oct 2013
    9
    Dec 2002
    Menzies Creek
    2,541
    I'm out sorry, having used both torsen and clutch diffs both on the track and the street, I wouldn't go back to a clutch diff. Its a personal preference, I know, but that's where I stand. Good luck with the group purchase.
    Nov 2001
    617
    The 3J plate ML differential is currently in design, with anticipated production in February.
    If anyone else is interested please let me know now.
    Nov 2001
    617
    ML Gearbox plate LSD will be available in a month or so if anyone is interested.
