306 slam panel stuck?
    64
    Default 306 slam panel stuck?
    I undid the two 13mm bolts and pulled the slam panel forward about an inch (see pic) to get better access to the radiator. Now it won't budge back towards the original position. Is there a trick to getting it back in place?
    tweed heads
    1,498
    Id be expecting to find some bolts or screws ,holding the bottom of the grill back .between the front skirt and the grill, you may have to take these out so you can pull the bottom forward then slide it back ,must be someone out there who knows how its done PUGS
    64
    I read one guide that says just hit it with a screwdriver and a hammer. Doesn't move at all though.
    64
    Turns out there are a couple of hidden guiding pegs that came out of alignment. Whacking the slam panel vertically downwards got them back into place.
