Sagging right rear - 1995 XR
    Jan 2006
    128
    Default Sagging right rear - 1995 XR
    My car has always sagged a bit on the rightside rear. By always I mean I started noticing about 4 years ago.
    Anyway recently the sag has increased and the inside of the wheel rubs on the plastic lining on the wheel arch going over gutters, offcamber speed humps, with passengers, etc. There is less than a finger gap between the tyre and the inside of the arch so it's pretty tight. The left wheel has about a 2 or 3 fingers and there is no rubbing on that side at all.
    There's been a few posts about this sort of problem on the forum and responses usually mention a worn torsion bar or tired damper but nothing definite, or what the fix was.
    I'm due for new tyres soon and at 195/15/55 the rubbing will become alot more pronouced with the new tread. I could go down to 185 but that would just be a temporary solution to the rubbing and won't fix the sag problem.
    1. What would be the most likely cause?
    2. Any recommended places in Sydney for inexpensive suspension check/replacement?
    Cheers all.
    64
    Any clunks or noise going over bumps?
    7,483
    Your rear beam needs rebuilding. If it has gone that far, you'll probably need a new trailing arm shafts and possibly even a replacement tube as well.
    Jan 2006
    128
    No clunks or bumps.
    As for rear beam rebuilding... ouch ...that sounds expensive.
    7,483
    Yep, $800-$1200. You really should have addressed the issue earlier. 306's are the same as 205's in the rear end.
    Jan 2006
    128
    That's teach me to listen to mechanics. I've asked several different mechanics that they check...nah they all said, suspension just a bit tired nothing to worry about
    You can buy a 306 for $1200 now.
