Hand Brake Spring
Results 1 to 15 of 15
    Apr 2012
    Hobart
    17
    Default Hand Brake Spring
    Can anybody offer advice. Have the back handbrake spring, which pulls off the handbrake, snapped. Mechanic tells me it is a common problem. But am unable to find a replacement, and because the handbrake slightly touches the disc when turning right it drives me crazy.
    Dec 2010
    420
    What sort of car?
    Via the aussiefrogs App
    9,004
    Quote Originally Posted by Gazza1 View Post
    Sure.
    Just take the discombobulator out, open the flux capacitor and replace the thingy-ma-jiggy with a do-ama-wacky and you're set.
    ACHTUNG ALLES LOOKENPEEPERS
    It's how I roll...Brisbane
    33,369
    Pretty sure the disc brake model didn't have the do-ama-wacky..
    9,004
    Quote Originally Posted by 59 Floride View Post
    You might be right, after 2012 they all have the whatsama dealie.
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,370
    504 i think is the machine Gazza is talking about. No idea about the spring though Gaz. Someone on here will help soon enough.
    Cam
    94 205 Gti Classic #9
    91 205 Si
    87 205 GTi Race Car
    Perth Western Australia
    2,694
    Years ago I adapted a coil spring to fit over the cable end to overcome this problem. Available from Bunno's.
    Then I read that one of the ES dealers were doing the same thing. SNAP!
    Seized handbrake mechanisms not uncommon on 504's. DON'T over adjust the handle.
    Dec 2005
    HOBART
    1,265
    I reckon I could find a complete unit among my spare parts, if you could make a trip across to the eastern shore
    Regards Gerry Mullock
    1998 Peugeot 406 D8SV Manual
    1999 Peugeot 406 D8ST Auto
    2002 Peugeot 406 D9SV Manual
    1994 Peugeot 306 XR N3 Hatch
    Over 60 Pugs in my time
    Gerry Mullock
    Fellow Frogger! gromzx's Avatar
    May 2011
    melborne
    364
    Normally the springs are available as part of a complete brake kit. Don't know about 504 though.
    2,694
    Well, bugger me! After shooting my mouth off on how simple it is to free off the handbrake I attempted to reverse my GL out of the carport. No go, the left side handbrake had seized. Using my trusty broom handle I reached under and gave the cable end a poke. Free at last!.
    A trip to Bunno's to get a spring [see post #7 above]. All I need now is energy, hay fever depleted, to get stuck in.
    SWOTR
    3,632
    If it's just the spring breaking you obviously need to replace the spring.
    If the lever is also frozen then you need to remove the caliper, remove the spring, tilt the caliper on its side with the white cap facing upwards, remove the cap, drip some oil into the fulcrum joint and keep on working the lever back and forth until its free. Then, replace the cap, replace the spring, replace the caliper.
    Sep 2004
    Tamworth UK
    624
    And remember to keep that oil off the brake pads
    2,694
    Peter,
    Like a lot of us on AF we have a big headed notion that we can improve on the manufacturer ie 5 speed boxes, multi carbs, big discs, altered suspensions etc.
    The extra handbrake spring I've suggested has to be an improvement [read cheap] on the hairspring return that struggles to cope.
    SWOTR
    3,632
    Peter,
    You may well be right, however, if you take a look under the plastic fulcrum joint cap you'll probably find claggy, dry grease. Lubricating, and therefore freeing up, this joint (and yes, being careful not to get oil all over the place) has fixed this problem on every 504 I've owned except for the one time I also had to replace a broken spring.
    1000+ Posts Beano's Avatar
    3,146
    It's tricky getting the right length and tension of spring. Too long or hard, and it's a real bugger to get on. Too narrow a diameter and it is impossible to slip over the cable end (happened to me once).
    A Pug place up here had a source of the right sort of springs but it (the Pug place) has closed down now.
    My 505 has this problem now but I'm ignoring it. As it's auto, I just put it in "park". And when I forget and pull on the handbrake, I have a trusty hammer in the back to tap in the arm. Time for an oiling, it seems !
