205 GTi water exi at the back of the block.
    Bendigo
    11
    Default 205 GTi water exi at the back of the block.
    I have just done some work on the head of my 205 as well as replacing all of the water hoses. At the back of the block on the left hand side (when facing from the front of the car) there is a point where three hoses feed into the block quite low down. The plastic connector where the water enters the block had broken. Please can someone tell me what this is called and where I could get one? Thanks in anticipation.
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    20,544
    While you re at it, might be worth while checking the block little higher up. When I pulled pulled my engine out, I found botch block repair. See the brown mild steel plug which had been used to repair a leak in alloy block. It had obviously had a corrosion leak in that area of the block.
    Every day is a good day
    7,483
    It's just called a water distribution block. Earlier cars have an aluminium version. Find one of those rather than buy a new plastic one - Peugeot dealer.
    Bendigo
    11
    Thanks. It's difficult when doing this work. The manuals don't always name the parts and there is rarely a good diagram. thanks for your help.
