306 Wiper Problem
    Oct 2005
    Panorama Heights, Devonport, Tasmania
    115
    Default 306 Wiper Problem
    The wiper only operates on the fastest speed. Do I look for the problem in the switch or at the w/motor, or elsewhere? PeterR
    Queensland , born a Croweater
    667
    simplest way is swap the switch and see if it works, thats probably the problem,fish make sure ignition is off when you plug the switch in,or will blow a fuse, maybe.
    guv
    guv is offline
    Sep 2013
    16
    Does your 306 have a rain sensor? If not there is blue relay behind the fuse box on the drivers side they can cause problems the motor itself does not control the speed.
    Via the aussiefrogs App
    Oct 2005
    115
    I tried another switch, but next move will be when I try another wiper motor.
    Oct 2011
    Toowoomba
    650
    Wiper motor has three brushes, ground and two others, one opposite for high speed, the other about 110 degrees around from the ground brush for low speed. If it's run out of low speed brush, this would explain what you're seeing. Intermittent uses low speed.
    Have fun!
    Oct 2005
    115
    Bruce, you were right on track with this. I have just tried and then installed a replacement motor and all works well. Thank you for your advice.Peter
