P505 Gearbox
Results 1 to 11 of 11
Thread: P505 Gearbox
    Feb 2002
    Tamworth NSW
    496
    P505 Gearbox
    I have just joined this forum today, so here is my first topic.
    About 12 months ago I had the gearbox on my wife's 84'505 STI Executive (manual)partially overhauled. The catalyst for the work was the need to replace the clutch (after some 350,000 km)The problem with the gearbox was a pronounced bearing whine with the car stopped in neutral, and the clutch out. The obvious diagnosis was the input shaft bearing(s).
    As a precaution, I had all 5 bearings associated with the rotation of the input shaft (in neutral) replaced. The other bearings were assessed as being OK. I also had the selector housing modified to include a gitz type seal, to supplement the 'O'ring on the selector shaft. That worked well, but not so the repairs to the whirring bearings, which remain as noisy as ever.
    In hindsight, I should have spent the additional dollars to have every bearing replaced, but I am not convinced this would have solved the problem. Any suggestions?
    Sydney NSW Australia
    137
    [quote]Originally posted by Kim Slattery:
    <strong>I have just joined this forum today, so here is my first topic.
    In hindsight, I should have spent the additional dollars to have every bearing replaced, but I am not convinced this would have solved the problem. Any suggestions?</strong><hr></blockquote>
    Kim - my question would be - did you replace the needle roller bearings in the gearbox main shaft?
    I had a similar noise problem with a 505 S2 Wagon some years ago.
    That was the only problem and interestingly, although I obtained the other bearings as well, (prior to removing the gearbox)I did not replace them (actually returned them for credit) as the old ones were in perfect condition.
    However, the needle rollers were stuffed.
    Denis
    [ 15 February 2002: Message edited by: Denis ]</p>
    Feb 2002
    Tamworth NSW
    496
    Hello Denis,
    Without consulting a parts manual, the only 'needle roller' type bearing that was replaced was that associated with the 5th speed, as the case hardening had worn off on most of the rollers. This was one of the 5 bearings done at the time.
    Perhaps the other rollers were worn more than first indiactions suggested?
    Kim.
    Nov 2001
    1,640
    Clutch Thrust Bearing?
    Rod
    Rod's Home Page
    Rod's car page
    137
    <strong>Hello Denis,
    Kim.</strong><hr></blockquote>
    Kim,
    No this is not what I'm referring to. The needle roller cage I'm referring to is positioned between the input shaft and the main shaft. If you have a Haynes manual, it is shown in figures 5.27 and 5.28 on page 140. It's a cage of 11 rollers, each about 10/11 mm long and 2.5 mm diameter.
    From what you've said about the noise, I could almost guarantee that this will be the cause of your noise problem.
    Denis
    :p
    Guru davemcbean's Avatar
    Apr 2001
    Camden NSW & Selwyn NZ
    2,334
    I agree with Denis.
    Dave
    NZ Fleet
    1976 504 Ti
    1984 205 GT twin carb
    1991 205 SI 1.6GTI motor
    1994 106 Xsi
    1996 Mondeo V6
    Aus Fleet
    1955 203C
    Feb 2002
    Tamworth NSW
    496
    Thanks to Denis and all other replies.
    As mentioned on my other topic, I am leaving for Spain today, and will not be back until the 27th March. I will try to monitor the forum whilst in Jerez.
    The repair to the GTI must be completed before I tackle the STI gearbox. I think you have all put me on the right track - thanks.
    Kim.
    9,223
    Bring back a couple of spare gearboxes then...
    Nov 2001
    1,640
    A workshop manual for my wife's Seat Cordoba would be nice too, Kim
    Rod
    Rod's Home Page
    Rod's car page
    9,223
    In Spanish, of course...
    Nov 2001
    1,640
    Qué?
    Rod
    Rod's Home Page
    Rod's car page
