2 questions re 1989 405 MI 16 1.9 litre
Results 1 to 9 of 9
    Apr 2012
    sydney australia
    17
    Default 2 questions re 1989 405 MI 16 1.9 litre
    I'd be grateful for some help with 2 questions please:
    1. I want to do an oil change but am puzzled how to remove the sump plug; is there a specific type of spanner or tool available?
    2. I have a noisy speedo, that gives a whirring sound and the needle vibrates annoyingly. Does anyone know of a DIY cure or is it a job for experts?
    Thank you
    David from Sydney
    Don't remind me!
    16,609
    There's an 8mm square tool for the plug. Try Bursons or Repco, else contact Newtools in Blacktown. Speedo cables dry out and cause flutter, replace with new and use third party heat shielding.
    Have you got a decent filter and new crush washer?
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    20,767
    Like Addo said you can get a tool.
    I use one of these, but all you need is small piece of square section steel and file/grind to size and turn with a spanner.
    Apr 2012
    sydney australia
    17
    thank you very much addo, i will chase up the tool from repco. i've got a filter but will have to get new crush washer.
    do you think that speedo cable replacement a DIY job or shall i consult my mechanic?
    regards and happy new year, david
    Apr 2012
    sydney australia
    17
    thank you 5 door, much appreciated, happy new year, david
    Jun 2011
    Brisbane Qld
    20,767
    I am not familiar with 405 in terms of access to the cable. If the access (particularly at the instrument cluster end) is ok it is normally a simple process.
    Mar 2003
    Tasmania
    1,419
    The sump plug on my Mi16 chewed up one of those crappy multi fit tools and twisted one I made from mild steel so I gave up and bought the proper fitting tool in hardened chrome vanadium steel from EAI....under $20 and worth every cent!
    Never had speedo cable trouble on mine...which is just as well as I had enough fun with the clutch cable to do me for a while!!!
    Pugs Rule!
    403, now sold
    404, project
    7,513
    Speedo cable replacement is not pretty. Gearbox end is easy enough. Just remove the plastic pin and withdraw the cable vertically. The other end however, requires access to the instrument cluster. So the binnacle needs to be removed. Get the new cable first so you can see what holds it in place.
    Don't remind me!
    16,609
    He can probably eyeball mine as the cluster is not yet installed.
