504 / 505 oil pressure sender - where is it located?
    Fellow Frogger! callipygous's Avatar
    Jan 2006
    Toowoomba
    798
    Default 504 / 505 oil pressure sender - where is it located?
    Where is the the oil pressure sender located on my Peugeot 504 XN2 engine? I have noticed that the oil pressure light isn't coming on when starting so my guess is it is disconnected - but I haven't yet found the sender. Can somebody please describe where it is?
    Peugeot 504 Intercooled T04 Turbo.
    Dec 2005
    HOBART
    1,265
    Quote Originally Posted by callipygous View Post
    You should find it on the alloy housing next to the oil filter. It's possible that the cable is disconnected/broken
    1998 Peugeot 406 D8SV Manual
    1999 Peugeot 406 D8ST Auto
    2002 Peugeot 406 D9SV Manual
    1994 Peugeot 306 XR N3 Hatch
    Over 60 Pugs in my time
    Gerry Mullock
    Jan 2006
    Toowoomba
    798
    Thanks, I'll have a look. Though I've got some external oil filter setup so it may be moved.
    Far North Queensland
    1,494
    If the external oil filter setup is an add on bypass oil filter, ie dunny roll filter, oil passes through it and straight back to sump, the origional oil filtration system should still be in place.
    They are intended to be used as an additional fine filter suplementing the origional system.
    Have heard of adaptors being used to allow commoner/cheaper oil filters to be used.
    Paul.
