fixing a 504 rear view mirror
Results 1 to 8 of 8
    petaluma, ca
    136
    Default fixing a 504 rear view mirror
    In trying to get the interior of my '74 504GL in top shape, I've struggled with the interior rear view mirror - the frame on mine was cracked and the mirror was fogged, both very common (if not nearly universal) problems on the salvaged 504s I've seen here in the states. After collecting 3 or 4 mirrors with one or the other problem I decided to take a mirror apart to see what the issue was. The mirror comes apart quite easily with gentle pulling and separates into the front frame with an afixed clear glass lens, a separate mirror, and the rest of the case that attaches to the car. I was very surprised to see (2 of 2 cases) that the fogging was not caused by wear and tear of the back coating on the mirror but instead to accumulated crud on the inside of the front lens (and a bit on the front of the mirror), all of which could easily be removed with glass cleaner. Whole unit snaps back together easily and looks great. Of course this fix will work better if your front frame has a little flexibility left in the rubber but even if not I managed to get two frames off and back on without cracking them. Give it a try if you haven't seen clearly out your rear view mirror in years!
    Lilydale, Melbourne
    2,097
    Good one! Thanks for the tip.
    Dec 2005
    HOBART
    1,265
    I've working on the mirror for my 504. A coat of tyre black on the case brings it back to pristine condition!
    1998 Peugeot 406 D8SV Manual
    1999 Peugeot 406 D8ST Auto
    2002 Peugeot 406 D9SV Manual
    1994 Peugeot 306 XR N3 Hatch
    Over 60 Pugs in my time
    Gerry Mullock
    Fellow Frogger! Doush_504's Avatar
    Cairo, Egypt
    636
    Thanks for the tip
    Will give it a try
    Chadi
    1982 504 SR white manual sedan with A/C (266 000 Km)
    2012 308 1.6 VTi Vapor Grey manual H/B (52000 Km)
    1994 405 1.6 white manual sedan (236 000 Km)
    1992 605 SV24 (91 000 Km)
    2005 406 2.0L automatic (Replaced with a 2013 C5)
    1983 505 GR white manual sedan with A/C (170000 Km)
    All since new
    Fellow Frogger! acf321's Avatar
    Feb 2013
    273
    I just found this thread and note for my 76 504 the whole interior mirror assembly is immaculate, but for foggy glass. I will gently heat the aperture and see if I can't prise the unit apart, clean and reassemble.
    Feb 2013
    273
    Just completed this task ... works a treat... until I went to put it back together and the inner mirror snapped in three pieces ..
    D'oh .... I need a new inner mirror!
    1000+ Posts Dano's Avatar
    Apr 2012
    1,362
    Try serie04, they have new genuine CIPA brand for 21.66 euros, plus freight. Good people to deal with, never a problem.
    rétroviseur - Série04 SARL
    1000+ Posts Beano's Avatar
    3,169
    ^^ I'm pretty sure I have one you can have for free, if I can somehow wrap it so it doesn't get broken in the post. Not sure though if its a 504 or 505. Were they the same size ? I can't remember. Sewnd me a PM if you want it for the cost of postage, but I still have to check.
