To BA10/5 or not to BA10/5?
Results 1 to 8 of 8
    Slovenia
    198
    Default To BA10/5 or not to BA10/5?
    Hi All,
    Okay, so my '75 504 GL currently has the standard BA7/4 gearbox, but I have a BA10/5 in good condition in the shed.
    I understand the general consensus is that the BA7 is the better unit. But if a 5 speed is available would that not be better? Regardless whether its a 7 or a 10? I should point out that the car is only ever used for 'Sunday driving'. I'm not interested in off the line performance or anything like that.
    Appreciate your advice.
    9,278
    Only if you do a lot of country driving on flat straight roads. Would be more worthwhile if you were to fit a 505 (4.1) diff as well. The 5 speed is simply a 4 with overdrive 5th added.
    Even then the 505 is struggling with the tall 5th and XN engine, sometimes you have to go back a gear, or even two if you wait too long, on a hill where the 4 speed would have gone up in top.
    Graham
    Quote Originally Posted by tonch504 View Post
    Hi All,
    Fellow Frogger! 1pugnut's Avatar
    wollongong
    444
    I fitted one in a 1978 504 that i had
    it was great having the 5th gear on the expressway
    I shortened the the shift and it made the box feel a bit harsh.
    regards Jamie
    series 2 405 mi16
    205 si
    series 1 205 gti
    series 3 205 with a gti6 motor project
    1970 404 ute 504 ti motor project
    parts cars 2 205 si's 306 sedan
    2004 206 gti180
    Our most Southern Member (Tas)
    277
    Changing to a 5 speed is a fantastic improvement in a 504.....if as Graham W says....change the diff.
    Dont believe all you hear about the 10/5 box.
    I have one in one car that is as smooth as any 7/5 but another that is a bit 'agricultural'...both are low mileage and in good condition....it is a bit of luck I think if you get a smooth one.
    Towing, I think most people would agree the 10/5 is a stronger unit and the gearing is slightly better in 5th I think.
    Put it in...you wont be disappointed.
    Fellow Frogger! BigH's Avatar
    Oct 2002
    206
    I have also done it in a 504 and agree entirely with Bob.
    1000+ Posts Shobbz's Avatar
    Brisbane, Australia
    1,284
    Agree that it was a good box. Bit of whine noise compared to the ba7
    Slovenia
    198
    Okay I'm convinced. I'll do it. A good time to do the clutch also I guess.
    Is it a direct swap or will I need a selector, bell housing? Anything else?
    wollongong
    444
    The bell housing will fit
    I used the 504 selector but mine was the late 504 selector that mounts to he back of the gearbox and then fitted in a rubber mount on he body it is similar to the 505 selector
    I think you will have the selector that mounts to the torque tube I don't know if that selector will work or not
    Also check that the torque tube will mate up to the gearbox you may have to machine the rear extension housing
    I also had to widen the Back of the gearbox tunnel for the rear of the box to fit in .
    I think that's it
    Regards jamie
    series 2 405 mi16
    205 si
    series 1 205 gti
    2004 206 gti180
