205 radiator drain plug problem
Results 1 to 7 of 7
    1000+ Posts pug-life's Avatar
    Geelong
    1,226
    Default 205 radiator drain plug problem
    Hi all.
    I was draining my radiator today and upon undoing the drain plug, the whole plug pulled away.
    Has anyone ever experienced a problem like this?
    What was your next move?
    Too thin to weld?
    Julian
    Fellow Frogger! DjB8V's Avatar
    8V'ville
    919
    Ouch. Radiator repair place ???
    205GTI - 8 valve, single cam coolness.
    9,044
    Brass or aluminium?
    I have kept my brass radiator just in case the aluminium ones become NLA in the future. Plus, I think they're easier to bodge on the roadside.
    Try soldering it if you're any good at it but for cheap insurance I would take it to a good radiator shop (assuming it is brass). If it's aluminium, it's time for a new one I guess.
    ACHTUNG ALLES LOOKENPEEPERS
    Geelong
    1,226
    Brass drain plug. So ill see if I can give it the old soldar treatment.
    I was hoping I didnt have to remove it...
    8V'ville
    919
    I remember twisting the top off the radiator in a 205 once. Removed the radiator cap and the collar twisted off with it. geezzzz I was angry after that...
    C
    19,211
    It's worth the time to remove the tank and silver solder the drain plug ferrule. Silver solder is a lot stronger than soft solder and will be a permanent repair.
    Good radiator repairers will usually silver solder all ferrules and the cap neck.
    Geelong
    1,226
    Thanks Robmac.
    I took it to a radiator repair crowd today.
    Pain in the backside having to pull it all out, but allows for access of further cleaning.
    Ill here back from them tomorrow i guess...
