504 front suspension noise in upper flexible mounting??
    Member Pughead2's Avatar
    Jan 2011
    Hepburn Springs,Victoria
    100
    Default 504 front suspension noise in upper flexible mounting??
    Hi Folks.
    The front upper suspension unit in my 82 504 has developed a 'metallic knock' when one puts downward pressure on the front guard.
    Struts are good,retaining collar is tight, top strut lock nut is tight and the noise is coming from the upper flexible mounting-I suspect its somehow worn but I cant ascertain where.
    Does anyone know of this condition, or had prior experiences with this issue?
    I'd appreciate a comment from the 504 clan.
    Regards.
    Pughead
    1000+ Posts Mike Tippett's Avatar
    Jan 2002
    Vancouver Island, Canada
    1,757
    If it's like the 404, the upper spring/shock mount has perished and the rubber has detached from the steel backing. The metal knocking is the safety cups.
    1966 Peugeot 404 Coupé Injection post-restoration reassembly underway!
    Register your 404: https://recensement.leclub404.com/submit.php
    Jan 2011
    100
    Quote Originally Posted by Mike Tippett View Post
    Thanks Mike.
    Im in the process of trying to locate a replacement unit.
    Regards.
    Pughead
    9,279
    I've got lots of used ones.
    Graham
    Quote Originally Posted by Pughead2 View Post
    Thanks Mike.
    Regards.
    Pughead
    Jan 2011
    100
    Icon7
    Graham
    Thanks for the kind offer Graham.
    We pulled it all out yesterday and found the problem.-this was the missing small nylon retaining ring which fits around the strut on the top side, under the retaining collar, this was causing a little movement in the koni strut,a rattle you might say. Anyway I needed the front end 'practice'.
    Regards.
    Pughead
    Jan 2002
    1,757
    Aha, I assumed you were using standard Peugeot shockers. I had that problem once with Konis in a 404.
