high idle
Results 1 to 3 of 3
Thread: high idle
    1000+ Posts Isis's Avatar
    1,100
    Default high idle
    Any ideas on why a car would start to increase its idle for no apparent reason. Mine used be about 1000, but is now 1600 and sometimes higher. Is my Motec system doing this? sticky cable?
    S3 205 GTI x 4 and getting lower
    1998 S1 Lotus Elise
    2013 Fiesta ST
    2014 Audi SQ5
    mullumbimby
    879
    I had this problem with a 306 and was advised to take off throttle body and clean with carby and injection cleaner.Didnt change much so then put injector cleaner in with fuel which did help and is what perhaps you could try first.
    9,053
    Vacuum leaks in the intake (past the AFM)? Wrong or inconsistent advance (dizzy caps wobble around), plugs old and tired (or incorrectly gapped), many other things (sensors defective) etc.
    ACHTUNG ALLES LOOKENPEEPERS
