mi 16 head.
Thread: mi 16 head.
    Fellow Frogger! le frogg 205's Avatar
    canberra city australia
    394
    Default mi 16 head.
    hi guys .tryng for the last two weekend to unbolt the head of mi 405 mi16 wat is the bolts size ? do i need a special tool ? i realy have to get it out ! have got to get read of the car.
    1000+ Posts cav91's Avatar
    Romsey, VIC
    2,337
    if it's still the oringinal it should be a T55 torx bit. Some of the after market ones are an inside out torx bit I think there M something.
    2017 Renault Koleos auto
    mullumbimby
    879
    If you buy the set from trade tools which is good quality and cheap have a good close look at the set . When I did mine the set I purchased had the 55 but was unsuitable for use with socket set so had to buy second set to tighten up head bolts.
    7,487
    T55 SnapOn. The 1/2" is best, but you'll have to turn down the outside diameter so it fits down the holes. If you go the cheap tool route, you're likely to bugger a bolt up and get yourself into more trouble. Use a 600mm breaker bar and you'll have no trouble, undoing, or tensioning up the new bolts.
    394
    thanks very mutch .am chasing a snapon truck in fyshwick right now!
