306 rallye water in driver's side footwell
Results 1 to 10 of 10
    May 2012
    140
    Default 306 rallye water in driver's side footwell
    2001 2.0l rallye - parked upwards on slight incline - rain overnight
    water in footwell (rubber mat thank goodness) and dripping while driving - will have a look today - any ideas why?
    cheers
    mullumbimby
    879
    Just aguess but bit of luck there'll be a leaf blockage.Lift bonnet and behind passengers bonnet hinge use hose or compressed air
    Melbourne Australia
    1,382
    Also can leak if you have a sunroof because of blocked drains in roof or in my case the outlet rubber tube connected to drain holes came loose. Only found this through part removal of headlining.
    Apr 2005
    866
    I've had water in the rear left footwell. Turned out to be some sand (after a trip to the beach) between the door and the seal allowing the water to wick through the seal.
    Tony.
    306 S16 1995 black
    Morris 1100 1965 green
    Lismore
    133
    door seals ARE the problem. i chased prob for few years. found that at certain angles water came thru seals. l saw drips coming thru fr of door trim pocket. extra self adhesive rubber strip 30mm x 3mm stuck to pinch welt cushion fixed it!
    172
    If you have a sunroof check the drainage channels that run down the A pillars. Mine were blocked which caused the sunroof to leak when parked on certain angles.
    Stu
    Sep 2012
    19
    Make sure your door seal isn't blocked.
    See video: http://www.youtube.com/watch?v=CgAQai-LEAM
    Sep 2004
    Tamworth UK
    624
    Also make sure that the plastic sheet inside the door is intact. If not any water getting in past the window scrapers will not get to the door drains, but run down the inside of the door because of the slope of the doors, and come into the car.
    1000+ Posts lion5's Avatar
    Jan 2013
    1,675
    just found out this is happening on my 2002 206 gti...
    Only found out now because i had to drive with socks, and realised the footwell was damp.
    Gotta check out the door seal tomorrow morning -_-
    Melbourne Australia
    1,382
    Just a bit of advice ......to dry carpet quickly go to a car wash asap and use their strong vacuums to suck up majority of water from carpet. It works a treat......
