505 GR steering rack woes - can I use a 'powered rack' without the 'power' ?
Results 1 to 11 of 11
    79
    Default 505 GR steering rack woes - can I use a 'powered rack' without the 'power' ?
    Folks,
    I have a GR (non power assisted) steering.
    The steering rack has a clunk in it.
    The car is unregistered and has to pass a 'blue slip' inspection. I do not expect it will do that with the 'clunky' rack that is in it.
    I have been looking for a decent rack but not had much luck finding one.
    I have a steering rack out of a 505 STI that is a power assisted system
    This posting
    http://www.505turbo.com/forum/index....steering-rack/
    suggests that I can use it.....all I have to do it plug the lines.
    Is it legal, will it work ?
    May I ask for your advices please.
    Many thanks in anticipation.
    Ted
    1000+ Posts Capago's Avatar
    Hornsby, NSW
    1,012
    Depends on the inspector really. If you plug it, they are not going to notice otherwise, unless they are really tuned into the car. Take it to any non-pug specialist/blue slipper and you should be ok.
    Member Gav_SV's Avatar
    86
    I removed mine in a 90 CRX I had, best thing I ever did. Made it tough parking and other slow speed stuff, but it was magic when driving.
    1998 406 SV
    Dec 2002
    Menzies Creek
    2,541
    It will work fine. Just be aware also that to use the power steering rack, you will also need the lower section of the steering column (which is shorter), and exhaust downpipe from a P/S model, and the sandwich plate for the PulseAir system needs to be fitted.
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    Oct 2011
    Toowoomba
    650
    You can get anti rattle kits, not too difficult to fit. Do the rack eye bushes etc while it's out of the car. The non-power 505 uses the same rack assy in early models as late 504, but the tie rods are longer, which menas that an early 504 rack will bolt to the crossmember but not match the tie rods.
    It will be very heavy to park with the power rack and no power...
    Fellow Frogger! Rally's Avatar
    Pearl Beach NSW
    548
    Hi
    I use a 505 power steer rack in the rally car with only 2 problems It is heavy to park and with the large castor angle I use it will load up a lot in tighter courners when you are going hard on the tar.
    I have a 505 GR non power rack if you need one.
    Andy
    Peugeot 504 Rally car V6
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    Peugeot 406 SV 5 speed
    Citroen DS23 EFi Safari
    Toyota Land Criuser V8 Super charged ( to tow the rally car )
    Rally with www.AMSAG.com.au
    Perth Western Australia
    2,694
    Ted,
    If the knock persists after all these knowledgable ideas, remove the upper steering column with the uni joints. Check for "knottiness".
    They can be freed up with a soft hammer blow then working them through their full angularity. Leaving the column overnight in an oil bath may help also.
    Feb 2001
    Romsey, Victoria, Australia
    4,878
    Quote Originally Posted by 505STI View Post
    Folks,
    This posting
    Ted
    A clunk in a steering rack is quite rare, are you sure its not a rack eye bush, anti rattle bush or steering flector. All of which are cheap and easy the change with the rack in the car.
    We have some second hand racks in stock if it does turn out to be internal but I doubt it.
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    79
    Folks,
    Thanks very much for your help.
    I'll follow advices above and get under it early Saturday morning and try and find out a bit more.
    Sincere appreciation for all the feedback.
    Ted
    8,431
    Get you $45 worth out of your blue slip inspection and let them tell you whats wrong with it, assuming they actually drive it to notice.
    If they dont notice it , great, and if they do there is something you need to fix.
    I do minimal prep for blue slips, and I'm always amazed when it gets through first go.
    Minimal means cleaning the engine bay, as a primary function of the blue slip inspection is to record vin and engine numbers.
    No one like working on a grubby car, especially not for the few dollars of profit the workshops make.
    Jo
    Pearl Beach NSW
    548
    Hi
    I have found my 505 GR non power steer rack if you still need it
    Andy 0414 223 817
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
