Hi all,
Well the old girl is back up and running after replacing some parts. But this morning I was presented with an idle speed of about 3000 rpm!?!
I've checked the icv thru a tester and it works. Oddly enough, if i clamp down on the hose that goes to the icv from the rubber between the afm and throttlehousing, I can regulate the idle speed. I've check for leaks - none found. I,ve pulled the battery and let it "rest" for 1/2 hour to try to reset the ecu to no avail. :-(
Is there a proceedure for resetting the idle?
