The what of who now?
François is a 1956 Peugeot 403 that I originally purchased in 2000. At that time, I did a very superficial clean up on him, and drove him around for a couple of years.
Being a very early model, he has clap-hand windscreen wipers, an ashtray at either end of the dashboard, lion on the bonnet, Peugeot badges down the side, the full word 'Peugeot' on the hubcaps and glass indicator and tail light lenses.
Oil pressure problems and worsening bearing noises combined with failing brakes meant it was time to retire François. He spent the next few years in a variety of storage locations, including backyards of houses and workshops, paddocks, and finally under a tree on a farm for a few years.
But upon seeing it there, my fiancé Kathryn commented that a 403 would make a nice wedding car. Well, did I have a deal for her! And so it came to pass that she agreed that we should restore François to use as our wedding car.
The plan.
The condition of the car when we rescued it from the paddock earlier this year, particularly the original mechanicals, was poor at best. Oil pressure issues, knocks from the front end, smoke, missing a cylinder, noisy gearbox, and a brake pedal that fell to the floor. The clutch slipped badly. The exhaust had fallen off. I still took great pride in driving it off the trailer and into the garage under it's own power though.
Overhauling the original mechanical components would be time consuming and prohibitively expensive for me. In an attempt to save as much of the budget for bodywork and paintwork, we have decided to use more modern components where practical.
Externally, apart from 504/505 hubs and wheels, it will look as close to original as possible.
Underneath though, there are some changes.
- 505 ZDJ engine, fitted with a Fuego carburettor and manifold, custom sump, Toyota 7M-GTE oil pump driven from the distributor drive in place of the original distributor.
- ZF3HP22 automatic transmission.
- 504 LD rear diff, 3.4ish :1 ratio.
- 505 disc brake front end
- 505 collapsible steering column
- 505 power steering
- air conditioning
The bits that I haven't finalised yet:
- Brakes. I have a couple of 404 brake boosters, but I am considering mounting a 504 master cylinder and brake booster on a frame to clear the diagonal members in the engine bay.
- Ignition. Considering Fuego and Renault 20 distributor options to fit on the back of the head, but clearance seems to be an issue.
Parts needed
We are still chasing some parts for François.
- Chrome strip that runs at the top of the sill panel, below the doors.
- Rust-free bonnet
- Right-hand tail light chrome surround to suit glass lens.
Photos
Today I did a first mockup of the engine and gearbox sitting in the engine bay to check clearances around the motor. Here are some photos.
