406 SV accelerator sticks
Results 1 to 9 of 9
    Member Gav_SV's Avatar
    86
    Default 406 SV accelerator sticks
    My 1998 3.0 406 sticks on full throttle. It drives fine when driven sedately but if the accelerator pedal goes near the floor it sticks on, and so bounces off the rev limiter.
    It can be reset by simply flicking the cable end attachement (on the throttle housing) OR by pushing the accelerator harder to the floor a few times. This is done after switching the engine off.
    It's actually causing the cable to physically stick on, it seems clean etc, all looks fine, so, I have no idea.
    HELP!
    1998 406 SV
    Jul 2004
    803
    Have you had the inlet pipe off? I have seen the metal ring come away from the inside of the pipe and jam the butterfly in the same manner in which you describe.
    2006 Peugeot 206 Xt
    1991 Toyota mx83 grande 1jzgte
    86
    I haven't, but I had some front end damage repaired. Maybe they have, So which bit am I looking for?
    1998 406 SV
    Jul 2004
    803
    Pipe from the air filter to the throttle body. Take it off and check the TB butterfly. If not disconnect the cable from the TB and work out which one is at fault.
    2006 Peugeot 206 Xt
    86
    Cheers mate. Hopefully I can get this fixed easily enough.
    1998 406 SV
    Member Ben1974504's Avatar
    Watsonia
    108
    Check your mat on the floor as it catches on the base of the pedal and sticks down , as happened to me on a few occasions so never left a mat on the drivers side , well check anyway
    5,312
    Quote Originally Posted by Ben1974504 View Post
    Mine too. Same cure, remove the mat.
    Mike.
    Started out with nothing, still got most of it left.
    1000+ Posts cav91's Avatar
    Romsey, VIC
    2,336
    I just moved mine down. Hasn't gone back up since!
    2017 Renault Koleos auto
    86
    Well James504 you nailed it mate!! One metal ring removed from the throttle body. What a nightmare it has been lately.
    I had front end damage repaired, and the shop has left me with 1) a radiator hose not properly connected. 2) A battery terminal on loose, and 3) This problem. Time to call my insurance company about the dodgy work from their preferred shop.
    1998 406 SV
