Cant get reverse !!
Results 1 to 10 of 10
    Fellow Frogger! keithscossie's Avatar
    Aug 2012
    Perth, WA
    141
    Default Cant get reverse !!
    Ok I've only owned the Dimma for 3 days so its a basic question folks.
    I cannot engage reverse at all.
    I lift the release and push as far as I possibly can and.... I'm in first once again.
    I have no history of the car at all so I dont know if the box has a quick shift fitted ( it could possibly have ) or is standard, stuffed or what.
    What do I look for ?
    As I said , basic stuff, but hey it's my first 205 !
    Keith
    1986 Ford Sierra RS Cosworth ( La Whore )
    Daily drive Widebody BMW 530d.
    Fellow Frogger! le frogg 205's Avatar
    canberra city australia
    394
    depending on what box you have its either next to first or under 5th. if it is next to first ,pull up on the tab and push across and up( to the left ). it should slide straight in. if not i would say there is something seriously wrong.
    good luck
    CitroŽn Tragic UFO's Avatar
    9,742
    Out on a limb here, but could it be that one of the linkage rods has popped off? Can you get all other gears?
    9,044
    Is it a BE1 'box? Sure? Maybe worth checking.
    If it is, check the cable is still there doing its job.
    Check linkages at crossmember balljoint and gearbox end for play.
    ACHTUNG ALLES LOOKENPEEPERS
    Fellow Frogger! Karoshi's Avatar
    Feb 2011
    268
    Could it be a gearbox change from be1 to be3 that they have left the same heartsick with the pull up on?
    I'm pretty sure the first 205gti I owned had the pull up gearstick but reverse under 5th. It was a long time ago but I'm pretty sure the pull up did nothing....
    87 build date that one was.
    Jan 2011
    Traralgon
    648
    Nah your car is stuffed mate, but don't worry - I'll buy it off ya cheep!!!
    racing 405
    1:59:09 last time at Phillip Island - less than standard Mi16.
    Don't remind me!
    16,609
    Quote Originally Posted by Karoshi
    ...heartsick
    Autocorrect LOL
    Aug 2012
    Perth, WA
    141
    Thanks guys,
    Had a chance to look properly today, with my specs on, and found the lift cable end had come out of the socket.
    All working well now.
    Another job off the list !!
    See some of you tomorrow at the Perth French Car day.
    Keith
    Feb 2011
    268
    Lol indeed!
    http://www.damnyouautocorrect.com/
    better ones here though...
    Glad you got the problem sorted
    9,742
    Good news - expecially when it's an easy fix.
