What does BSM means?
Results 1 to 10 of 10
    Fellow Frogger! Ikenna351's Avatar
    Abuja, Nigeria.
    297
    Default What does BSM means?
    Please, what does BSM means in Modern Peugoets?
    I was made to understand that its an engine fuse box. Its that true?
    Ikenna
    Don't remind me!
    16,609
    No, that's PSF1. Inside fusebox is normally BF.
    Abuja, Nigeria.
    297
    I think there is something that looks like BSI unit in D9 engine bay called BSM. What's the meaning of the acronym BSM and what is it function?
    Ikenna
    Don't remind me!
    16,609
    I don't know. PSF is "Platine Servitude Fusibles" and BF is "Boitier Fusibles".
    It is possible someone is re-naming the PSF unit.
    Sep 2003
    North Parramatta
    3,997
    That is what a lot of people refer to as the fuse box assy in the engine bay, using this eBay link as an example. I've also seen it referred to (perhaps more correctly) as the BF34 or BM34.
    I love how all these names refer to the same thing
    AFAIK, a PSF1 is the "engine connection board" and a BM34 is the "engine fuse board" (in this case, the 34 means there are 34 fuses). Perhaps due to the confusion, people have dreamed up the term BSM to refer to the collected bits as one unit, but BSM is not a Peugeot term, I gather.
    My post has probably confused you even more. Sorry about that.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Don't remind me!
    16,609
    PSF1 is the one which carks regularly, named a BSM in the Ebay links.
    Were I to own a car newer than 2000, I would carry one as a spare.
    May 2004
    Melbourne, Australia
    228
    BSM is the engine bay fuse box. (also known as PSF1 or BM34 on wiring diagrams.)
    It is known as a BSM because that is what is printed on the unit itself.
    (Addo is right, have a spare!)
    spiz
    Fellow Frogger! Molerpa's Avatar
    Jul 2005
    South America, Argentina, That country that looks like hanging from the map... just about to fall...
    492
    Would it be BCM? (Body Control Module) which is the generic name for the device that controls all what goes on the body (power window, headlights, central locking, yada yada yada).
    Quote Originally Posted by luthier View Post
    It is simply impractical to expect a petrol motor to get through too much water. That's why God invented diesels.
    9,973
    Boîtier de Servitude Moteur or words to that effect as I understand it. It's the engine slave unit, which normally incorporates fuses and relays encapsulated in sealant. It's essentially a slave unit under the control of the BSI, which is the fuse box in the back of the glovebox. The BSM carries most of the switched electical loads.
    Sep 2003
    North Parramatta
    3,997
    Quote Originally Posted by Molerpa View Post
    No, the BSI is the unit that controls things that other manufacturers would refer to as the BCM
    It's located under the dash or the glovebox (depending on model).
    Simon
