Peugeot 405 Mi16 Series 2 engine query
Results 1 to 11 of 11
    Member Cole's Avatar
    Oct 2005
    Lismore
    75
    Default Peugeot 405 Mi16 Series 2 engine query
    Hi all,
    Looking for a replacement motor for my Series 2 Mi16. Have managed to find one. The complication is that all Series 2 Mi16's that I'm aware of have the RFY XU10J4. However this one I have found is a RFT XU10J4. Would anybody happen to know the difference? This motor may have been sourced from overseas I'm unsure. So if anybody with a late Series 2 would mind checking their VIN numbers to see if anybody does have the RFT, as the theory is it wasn't brought in to Aus.
    Thanks All
    Brendan
    Jul 2004
    803
    RFT refers to the XU10J4 + its specific engine managment. Physically both RFT/RFY motors are the same.
    2006 Peugeot 206 Xt
    1991 Toyota mx83 grande 1jzgte
    Oct 2005
    Lismore
    75
    So does that mean the difference is the ecu?
    Is the rest the same?
    If i were to get this motor would it be compatible with all the rest of the componentry that I have? Or is there more to this swap that I will need?
    If only the ecu is there somewhere i can get the right one?
    7,514
    The differences in the three digit codes always confuse me. The only difference between an S16 and an Mi16 engine from what I can gather is the vacuum pump. It's fitted to the cam sensor housing on an S16 to provide vacuum for the brakes. For some strange reason, the Mi16 doesn't have one.
    One other small detail. I think all S16's have a windage tray, but only Mi16 engines from 11/93 onwards have a windage tray.
    In summary, if it's an S16 engine, it can only be a bonus for you.
    1000+ Posts Capago's Avatar
    Hornsby, NSW
    1,012
    all the power changes in the 2l xu10's are just in the management yes? varies a bit in power but torque is very similar
    Oct 2005
    Lismore
    75
    So to clarify, the RFT came out of the 306 specifically? And was this available in Australia? And if the difference is the computer can you simply swap it over? As i already have a spare RFY ECU
    Sep 2003
    North Parramatta
    4,003
    According to Peugeotlogic, the only difference is the kW are 108 vs 111 and Nm are 150 vs 155. They both share the Motronic MP3.2 injection.
    There must be a reason for it being a little down on power and torque, but I've no idea what it is.
    As for 306 exclusivity, it could easily have turned up in a 405 or a PSA product from CitroŽn.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Sep 2003
    North Parramatta
    4,003
    You're in luck - this late model Australian-delivered 405 Mi16 (1994) on CarSales has a VIN suggesting an RFT motor: VF34BRFT271387208
    Simon
    Don't remind me!
    16,609
    Quote Originally Posted by SLC206
    Cam timing, probably.
    Apr 2005
    866
    hmmm that torque figure doesn't sound right. pretty sure the S16 motor is 192Nm toruqe. KW sound about right though.
    Tony.
    306 S16 1995 black
    Morris 1100 1965 green
    Sep 2003
    North Parramatta
    4,003
    Quote Originally Posted by Wintermute View Post
    My apologies, the second figure is hp, as quoted on the Peugeotlogic link.
    Simon
