flutter/fart noise coming from somewhere
Results 1 to 12 of 12
    Feb 2001
    493
    and no it's not the driver!
    ok after i got my brakes changed, i have noticed this flutter noise coming from somewhere while i'm driving. I can hear it when driving next to a wall as the noise bounces back. It sounds like a constant flutter like an exaust with a hole but its not loud. Is there a common prob with the 306 that would make this noise? I've tried looking arounf the car, can't really find where its coming from
    thanks
    1000+ Posts brenno's Avatar
    1,937
    I have a noise like a pad lightly rubbing on a disc from the front - and yeah it sounds like a flutter.
    That changes to a kssshshshshsh noise (like that?) when the brakes are being applied though.
    Maybe we should meet up and compare.
    Feb 2001
    493
    you reckon the grooved discs make the noise??
    1,937
    Yeah thats what I think it is.
    My room mate has a VT Clubsport and he got drilled AND slotted rotors and they make s ksshshssh noise quite loudly.
    Nov 2001
    1,640
    If the noise is proportional to engine speed I'd be guessing a leaky exhaust (probably manifold or down pipe). You can usually tell this one because of an increase in noise on decelleration
    If the noise is proportional to road speed I'd be guessing a slightly warped or unevenly worn disk
    Rod
    Rod's Home Page
    Rod's car page
    6,496
    I've heard cross-drilled rotors making a sound kind of like flicking your finger back and forth across your lips rapidly while you blow out
    Maybe it's the same with slotted ones (if that's what you ended up with?????)
    Stuey
    2003 PEUGEOT 206 GTi
    Feb 2001
    493
    [quote]Originally posted by Stuey:
    <strong>I've heard cross-drilled rotors making a sound kind of like flicking your finger back and forth across your lips rapidly while you blow out
    Stuey</strong><hr></blockquote>
    Yeah thats the sound!! the discs aren't cross drilled, just slotted on spot drilled i think its called. The holes don't go all th way through. But the noise doesn't seem to get any louder at speed, so i don't think its teh exaust. If it is an exaust, i guess that will be another excuse to get a sports exaust!
    6,496
    ...come on now, own up. How many of you pursed your lips, blew out, and flicked your finger across them?
    Stu
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    Not Me!!!
    I just farted instead :p
    Alan S
    May 2001
    Melbourne, Victoria, Australia
    23
    ROFL! I must confess, I did Stu! Sprung!
    Nov 2001
    1,640
    [quote]Originally posted by Pugsly:
    <strong>
    But the noise doesn't seem to get any louder at speed, so i don't think its teh exaust. If it is an exaust, i guess that will be another excuse to get a sports exaust!</strong><hr></blockquote>
    Exhaust noises usually appear to DECREASE with vehicle speed, Pugsly, but increasewithhigh load and deceleration situations .
    Its simple to tell the difference. Just run the engine with the car stationary. If you can hear the noise, and it increases in speed ( - ie more farts per minute - not necessarily louder) when you rev the motor, its exhaust / engine related.
    If the FPM ("farts per minute") increase with vehicle speed (regardless of what gear you are in) and aren't apparent with the vehicle stationary, its related to the running gear (most probably the brakes, although wheel bearings are another possibility.)
    Rod
    Rod's Home Page
    Rod's car page
    Feb 2001
    493
    Thanks Rod, makes perfect sence! Maybe i should pop down to jaycar to see if they got a FPM meter kit
