LED trailer lights
Results 1 to 8 of 8
    Jul 2004
    896
    Default LED trailer lights
    Before I waste time and money buying LED lights for my trailer and find they dont work because of the multiplex system's sensitivities in my 308....
    Has anyone put LED Lights on their trailer for a recent PSA model car and had any issues??
    If there could be a problem I might have to take the long approach and experiment with LEDs and current limiting resisters to get the current draw to match what incandescent bulbs draw
    Decca
    Present --2016 2008 Outdoor / 2014 RAV4 Diesel (My utilitarian beast)
    Jan 2003
    Campbelltown NSW
    159
    Narva sell load resistor for thier led lights.
    Tim
    Should get a life 2353's Avatar
    Brisvegas
    4,049
    Quote Originally Posted by Decca View Post
    Decca
    Quote Originally Posted by Tim_K View Post
    Tim
    If the world was rational, there would be no need for a manufacturer to develop or sell device to "waste" power in a car so the computer thinks that everything is working correctly! It's somewhat illogical.
    Save the earth, it's the only planet with chocolate.
    Jul 2004
    896
    Quote Originally Posted by 2353 View Post
    I think you're stating that the 'computer' will compensate for all conditions???
    Low power consumption is an ideal but the car's setup may have to compromise for some things
    I have found that if an indicator on the trailer doesnt work then the indicators on my 308 flash slow.
    So I'm assuming the electrical interface unit ( that makes the 308's towbars so expensive) is looking for a certain current drain from the trailer's lights for the car's and trailer's lights to work successfully
    Decca
    Jan 2011
    adelaide
    154
    just replaced the old lights on my trailer with LED towing behind the 03 C5 all working fine. Picked up the LED lights on Ebay $18.00 pair plus $7.00 postage.
    19,213
    I'd some some IGBTs (you may be OK with plain BTs) controlled by the existing wiring and use them to switch the trailer light loads.
    That removes any possibility of problems.
    My
    Fellow Frogger! Psychlone's Avatar
    Apr 2011
    Melbourne, Australia
    252
    My 307 doesn't like it if I keep the lights off, the trailer LEDs flicker. If I put the parkers on then they all work perfectly.
    Jul 2004
    896
    My
    I still might have problems as the BT may not be the correct load for the wiring interface unit
    Quote Originally Posted by tazzy View Post
    Is this a Multiplexed wired car?
    Quote Originally Posted by Psychlone View Post
    Sounds like something is wrong there Psychlone
    DEcca
