Experiences with Vegetable Oil Diesel in Old French Cars
Results 1 to 15 of 15
    Fellow Frogger! IThompson's Avatar
    Sep 2011
    Bendigo / VIC
    226
    Icon5 Experiences with Vegetable Oil Diesel in Old French Cars
    Anyone had experience with using Vegetable oil from Fish n Chips shops in an old Peugeot Diesel?
    I am guessing that Vegetable oild would cause havoc with a new Diesel. What about old 504s or 405s?
    It seems like an interesting thing to experiment with.
    Ian
    Don't remind me!
    16,609
    Quite a lot of the to-and-froms use "WVO" in Xantia and 306 diesels.
    They are fussy about DIY bulk filtration, preheating and the type of injection pump (I can never remember if it's Bosch or Lucas that is unsuitable). Also a noted relatively frequent occurrence is clagging of the pick-up screen with gelled heavy oils. HDis and newer, aren't going to be happy.
    Citroën Tragic UFO's Avatar
    9,809
    Do you want to deep or shallow fry them?
    Welcome to AF.
    There are some people around and especially a guy in Sydney who has done extensive work in this area. He ran/runs his 405 diesel on fuel he distils from chip oil. I wonder if seagulls follow him?
    1000+ Posts gezza's Avatar
    Bunbury
    2,191
    I used to always run my 306 d turbo on vege oi,l one tank of vege then the next tank of diesel and so fourth, just have to change filters more frequently
    Far North Queensland
    1,494
    The injector pump is the critical part.
    When I was looking into running a 504 diesel on biodiesel I found warnings not to run WVO if the car is fitted with a rotary injection pump. Apparently the extra drag will shear off the drive on the Rotodiesel injection pumps in 504s. In line injection pumps were said to be ok.
    Paul
    1000+ Posts bigkev414's Avatar
    Mar 2011
    gold coast queensland
    4,511
    Quote Originally Posted by IThompson View Post
    Ian
    If I put the oil from any of our local fish and chip shops in ANY car would spit it straight out at me!
    I might act like an idiot, and I might look like an idiot, but don't let that fool you: I really AM an idiot!
    Sep 2011
    Bendigo / VIC
    226
    What does "to-and-froms" mean?
    My nick name used to be seagull so I had better investigate this further.
    Ian
    Jul 2005
    328
    Ian
    Rhyming slang for 'Poms'.
    '96 Peugeot 405 SRDT Station Wagon
    '71 Peugeot 504 GL - gone
    '91 Peugeot 205si - gone
    Jun 2003
    Lauderdale, Tasmania
    2,888
    As I recall from my student days there were many fish and chip shops in the North of England that fried in Diesel oil.
    1,494
    Quote Originally Posted by gerry freed View Post
    Taste that bad did they?
    Even though the emphasis these days is on healthy polyunsaturated oils a lot of "fish and chip" shops prefer to use animal fat. The most popular being "Frytol". Their justification being that the fried product drains better and the customers prefer the taste.
    Even when a shop uses vegetable oil for their frying it becomes contaminated with fat over time.
    Long gone are the days of shops peeling and chipping their own potatoes.
    Chips these days are purchased precooked and frozen.
    And what are they precooked in? Animal Fat as clearly stated on the label.
    I like to make my own chips and cook them in peanut oil.
    Paul
    “A straight is merely the distance between two corners.”
    “Corners: radar free zones.”
    Current: Peugeot 205 GTi Mi16 1987
    Peugeot 205 Si, one red one silver, both 1991.
    Peugeot 504 Wagon, V6 and 5 speed gearbox.
    Isuzu (Holden) Rodeo, 4WD dual cab, extended chassis.
    Past: Goliath, Isuzu Bellett, Austin A30, Peugeot 203, 403, 404, 504,505.
    Subaru 4WD wagon, Toyota Hilux Dual Cab Diesel 4WD.
    Makotrac 205 GTi 06-05-2012 best lap 1 min 20 sec.
    Banned
    sydney, australia
    11,301
    does the animal fat make the oil unsuitable for conversion into biodiesel, or just add some complications?
    Jun 2003
    2,888
    the exhaust makes a mooing noise.
    1,494
    Just further complications.
    The fat is harder to convert usually requiring a higher percentage of "methoxide" (sodium hydroxide dissolverd in methanol) and a longer processing (mixing) time.
    Biodiesel made from fat has different characteristics than that made from vegetable oil.
    It has a higher cetane value which gives a quieter engine, not so much diesel knock.
    Unfortunately it has a higher "cloud point" (gelling") so in winter it can cause filter plugging unless there is an inline fuel heater fitted.
    Most biodieselers try to source used vegetable oil.
    One of the best is Eta Salfry, a mixture of soy and canola oils.
    It processes very easily.
    Have done a bit of research on biodiesel, worked as a consultant for a rendering company setting up a biodiesel plant and have made biodiesel from all sorts of fats and oils ranging from grease trap waste to butter.
    The butter biodiesel was a lovely drop.
    Paul
    Feb 2001
    Romsey, Victoria, Australia
    4,904
    I bought a 505 turbo diesel from a guy near me in Kyneton (where the temp is often below zero) and he ran it on straigh chip oil from the local chip shop.
    He didn't filter it or boil it, nothing, just had a few 44 gallon drums in his shed full and let them sit for a few weeks so all the crap settled and poured it in. Car had done over 300,000 when I got it and I used it as a tow car for a while and did a few thousand kms and never had a problem. He did tell me he changed the filter about every 5000km and the car had a distint smell about it but never had a problem.
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    frenchconnect@bigpond.com
    1,494
    Lots of accounts of vehicles being run long distances on vegetable oil.
    Also lots of horror stories of sump oil contamination, clogged piston rings, injector pump failure and poor spray from unmodified injectors.
    Some vehicles respond better than others.
    The jury is still out in my opinion.
    Elsbert in Germany produces engines designed to run on SVO and also kits to convert existing diesel vehicles.
    Optimum conversion is a two tank system with heater for SVO.
    Start on petroleum diesel, switch over to SVO when same has warmed up, switch back to diesel before shutdown.
    There was a very interesting account of a journey through the USA to Mexico in a converted VW Golf,on one of the alternative fuel forums. It was titled "SVO to Mexico". Made great reading but can't testify to its veracity.
    http://www.biodieseldiscussion.com/f...ead.php?t=7435
    Paul
