Bonded windscreen removal
    1000+ Posts Haakon's Avatar
    May 2002
    canberra...
    8,876
    Default Bonded windscreen removal
    Does anyone know a good method of removing bonded windscreens (ie from a R25) without breaking the glass?
    16,756
    Enormous amounts of luck
    Seriously, it's like removing side/rear bonded windows. You need to pass something like a piano wire through the glue and cut the sikaflex's bond before lifting the screen out ... Should be do-able, but very, very time consuming
    Aug 2003
    Hamilton, NZ
    10
    Quote Originally Posted by Haakon
    The best thing for you to do without having to buy expensive cutout tools is to go down to your local glass shop and ask for a roll of windscreen cutout wire. The stuff we sell here is triple stranded and is gold coloured.
    Then, cut a length off about 2 or 3 feet long, poke one end through the urethane under the screen, and then attach something like a spanner on each end. Get a mate to help you, and use a sawing motion back and forth. Before very long you will find the wire cuts through the old urethane like a knife through butter! Only take you a few minutes and it will be out...
    Fellow Frogger! briz205's Avatar
    Oct 2003
    Auckland New Zealand
    894
    hI,
    I use a piece of brake cable and clamp vice grips to either end using the cutting motion i have yet to break or damage a window.
    Cheers Nick
    May 2002
    canberra...
    8,876
    Thanks guys. Seemed a shame to see a perfect windscreen go to the crusher along with the shell, and my screen is a bit worse for wear following its encounter with several roadtrains en route to Perth
    XTC
    XTC is offline
    Mar 2003
    Location Location Location
    8,566
    I was going to say make sure you touch up any metal part that gets exposed (paint scrapped off) .. but it's hardly worth if if it's going to the compactor !
    - XTC206 -
    Now this is a .sig
