Car Stereo Problem
Results 1 to 25 of 34
    Gordon, NSW
    4,527
    Default Car Stereo Problem
    Hi Guys,
    Got a strange problem with the stereo in the Pug. The audio keeps cutting out, will play for 2 seconds, and then out for 4 seconds. It's very consistent.
    The headunit shows that signal is still being read from the radio or CD, as it has a graphic display that moves in time with the music. Gimicky, but at least it tells me the unit is receiving a signal!
    The amp has a power light and does not fluctuate as it cuts in and out. I've replaced the fuses on the unit to no avail. All plugs appear to be OK.
    It's an Alpine CD head unit and an Alpine MRV-405 Amp.
    Any ideas?
    Lincoln
    Fellow Frogger! Andreas's Avatar
    Sep 2000
    1,200
    check the earth on the amp, might not be securely screwed down.
    Fellow Frogger! Reno's Avatar
    1,260
    yar, sounds like a bad earth.... loose contact.
    Gordon, NSW
    4,527
    to the amp it's secure. i don't install stereo stuff myself, what is the earth secured to normally?
    Sep 2000
    1,200
    you'll have two larger wires going to the amp.
    one will be for power coming from the battery possibly via a distribution block or inline fuse holder.
    the other is the earth and will be screwed down to bare metal in the car somewhere, if the connection is loose the amp wont work.
    16,750
    Could be the speaker wires shorting somewhere too. This will cause the headunit/amp to shutdown temporarily ...
    Gordon, NSW
    4,527
    Quote Originally Posted by Andreas
    power is coming from a line with an inline fuse holder. the earth cable i can follow to the seat frame, near the wheel arch, attached to some metal.
    Gordon, NSW
    4,527
    all of the speakers are cutting out. I've tried disconnecting the speakers one set at a time and swapping them around to no avail
    Sep 2000
    1,200
    well if the earth is fine could be the remote wire coming loose.
    doesnt sound like anything major, just a loose contact somewhere.
    do you know if the amp is staying on or is it shutting down?
    ...just read the light stays on so it's not going to protection....
    Gordon, NSW
    4,527
    The amp stays on. Power light remains on. Checking the remote wire now...
    Gordon, NSW
    4,527
    remote wire had frayed a bit, so i took it out and reattached it, still no change Except I think it's resetting after 3 seconds instead of 4...
    1000+ Posts Damien Gardner's Avatar
    Jan 2001
    Wendouree Vic. Aust
    2,436
    Quote"
    Any ideas?
    Lincoln
    End quote
    Lincoln,
    Your description, sounds very much like thermal shutdown, of the output stage.
    This occurance will not effect anything before the output amp, being IC Transistors or what ever, many things can cause it, like Shorts in speaker cabling, Too high a speaker load, or simply not enough ventilation, to cool the amp, if this were the case a 12v computer cooling fan, blowing over the amp cooling fins, will work wonders. Keep in mind the higer the wattage. eg 200W x 2 means the amp is producing 400Watts of heat on full load and most likely would be too hot to touch.
    hope you find your problem soon.
    Health and good fortune always,
    Damien.
    We rode on the winds of the rising storm,
    We ran to the sounds of thunder.
    We danced among the lightning bolts,
    and tore the R10's assfromunder.
    Robert Jordan & memyself&I
    1/48th Scale Alpine A310,
    N-scale 1/160th Renault & Citroen, Advert. Signs & Billboards
    Gordon, NSW
    4,527
    If it did overheat, would it cause this ongoing problem? The carwas used to move house the other day and was covered with a blanket for a bit to avoid scratching it up...
    The amp isn't hot when this is happening. The car is sitting in the garage now and hasn't been used all day...problem has been around for a couple weeks
    Jan 2001
    Wendouree Vic. Aust
    2,436
    Does it do it from switch on or after a while?
    Damien.
    Jan 2001
    Wendouree Vic. Aust
    2,436
    Did it start whilst covered with a blanket?
    Damien.
    Gordon, NSW
    4,527
    Quote Originally Posted by Damien Gardner
    From switch
    I believe so. Was only a cotton doona cover... for around an hour
    Jan 2001
    Wendouree Vic. Aust
    2,436
    Several circumstances can cause it, if it has a fault it will trip the internal heat sensor, and will display intermitant characteristics. However if the outputs have been damaged the amp could well display this effect permanently.
    Damien.
    Gordon, NSW
    4,527
    I would've thought it'd just blow a fuse if it had overheated.
    Also, the problem was just intermittent cutting out on the radio. The current problem happened a couple days later...
    Jan 2001
    Wendouree Vic. Aust
    2,436
    Sounds like it might be worth while having a chat with a tech specialising in auto Amps.
    My field is PA desks/amps, band equip & broadcast equipment and Transmitters up to 13kW, with 2BOB Radio Taree and 3CCCFM Bendigo
    Damien.
    Jan 2001
    Wendouree Vic. Aust
    2,436
    BIG Question Was there any synthetic materials anywhere near it?
    Damien.
    Gordon, NSW
    4,527
    Thanks mate, appreciate the effort.
    Thanks Andreas and Julian too! I'm sure Tonia has kicked something loose under the dash somewhere. I'l have a good look under the dash there
    1000+ Posts CHRI'S16's Avatar
    Jun 2002
    3,298
    Lincon, sounds like the A/V socket music output from the head unit, Thermal shut down on those series alpine amps takes a while (5mins++) to return to normal. So with out looking at it... to me the fact that its consistent and it happens reguraless of source (is cd/radio) then the output transistors couldbe a little shot....
    306's don't put the head unit i a good position, when looked at from a heat point of view, its got very few places to go, and if tanya parks outside in a hot day it can cause the head unit to have bit of heat stroke...
    Thats a worse case cenario. do the little things first, check all plugs are tight and all leads in tight, also at the battery terminals and all wiring all nice and tight, check the fuse holder, the plug in the back of the head unit if possible etc.
    Then if no avail seek help. cheers chris
    ... ptui!
    Gordon, NSW
    4,527
    Problem is I don't have the key thingy to rmeove the head unit for the Alpine. So I can't pull out the head unit and check. Do you have one?
    1000+ Posts brenno's Avatar
    1,937
    Linc,
    I think I have an Alpine MRV1005 around here somewhere that you can swap to see if the amp is causing the problem.
    You'd have to pick it up as I'm finding it hard to get around at the moment.
    BC
    Gordon, NSW
    4,527
    thanks Brenno!
    In looking around the car, Tonia discovered a under seat compartment on the paseenger's side. In it we found all of the manuals and log books the previous owner thought were lost! I never knew that was there. Is this a normal feature on the 306?
