Running on
Results 1 to 3 of 3
Thread: Running on
    Banned Haakon's Avatar
    May 2002
    canberra...
    8,919
    Default Running on
    Ok, I thought it was impossible for a "modern" EFI equipped car (ie my R25) to run on, as the fuel is shut off with the ignition.
    But today, after a hard 180km run down from the country in 35+ degrees at 120 kph with the AC on full bore and a temp gauge sitting 4/5 of the way up the gauge (fluctuation up and down according to road gradient...), I pulled into the drive and backed up the garage and turned it off and the bloody thing ran on . It did this for a few seconds, and then I reignited the ignition, let it idle for 20 seconds or so and then turned it off successfully...
    It was bloody hot and I would have expected it from the Fuego and let idle for a while, but I always thought it was impossible form EFI
    Do I have leaky injectors, dribbling enough fuel in from residual line pressure to fuel the running on from what were undoubtably glowing plugs?
    12,273
    i'd nearly say you have a carbon build up in the pots
    when was the last time you ran redex or similar through the car ?
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    May 2002
    canberra...
    8,919
    Had the head reconditioned (new guides, valves refaced, seats reprofiled, bead blasted etc) and the piston tops polished 20K km ago. Has fresh Valeo plugs too.
    Being run mostly on premium fuels, and mostly country driving.
    So I would say the combustion chambers are spotless.
    But I can can buy the fact that it was extremly bloody hot and the plug tips were hot enough to cause run on, but I didnt think it would have had a fuel supply to do it....
