Easiest way to remove Pin Stripes
Results 1 to 19 of 19
    Fellow Frogger! Mitch Mi16's Avatar
    Oct 2003
    Sydney, Australia
    568
    Default Easiest way to remove Pin Stripes
    Ok i've been removing the pin stripes on my car, and they can be a bit stubborn, breaks rather easily.. I read that an easy way to debadage cars, is to use a hair dryer to loosen the glue, the pry off by using dental floss under the corner..
    Do you think that using a hairdryer on the pin stripes might make it easier to peel off. I've just been using my finger nails to peel it cause i wasn't sure of what else to use without scratching the duco..
    If anyone has a simple way to do this, please let me know.. Sitting there for 10 mins and only getting say 5cms along can be pretty tedious. plus i'm looking for a quick and easier way..
    THE MAD PUGGA
    1989 405 Mi16 (PGT-405)
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    If you have access to a Karcher or Gerni, simply blow them off.
    Turps is what is used to remove the glue.
    Alan S
    Oct 2003
    Sydney, Australia
    568
    I actually have a family friends Karcher at the moment, but i think the water restriction might cause me a problem, So you think turps would do the trick??? Would it affect the paint though??? Obviously not hey...
    THE MAD PUGGA
    8,923
    Mitch,
    By trade I'm a fridge mechanic and I've washed thousands of stickers off fridges using turps with no after effects.
    Turps isn't a solvent for car or appliance paints but works well on those rubber based glues. Sometimes needs a bit of time to soak in & soften, but if you have side strips, just be careful not to let any run down the back of them as they use the same glue on them.
    Alan S
    Oct 2003
    Sydney, Australia
    568
    You mean the black bumper type parts on the side..
    Thanks for letting me know... could have cause some probs if i didn't know
    Cheers..
    THE MAD PUGGA
    8,923
    Some of those are held on by speed nuts, others held by glue; best not take the risk if you're not 100% sure.
    Alan S
    Citroën Tragic UFO's Avatar
    9,784
    I have been told that the hairdryer method works very well.
    Oct 2003
    Sydney, Australia
    568
    Cheers, might try the hairdryer trick first, then if it doesn't help, revert to the turps...
    Cheers Guys..
    Mitch
    THE MAD PUGGA
    Fellow Frogger! Jez 405's Avatar
    542
    Hammer and chisel. Works every time
    Seriously, I've always used a hairdryer and acetone to remove badges, dealer stickers and decals and it works fine. You need some cotton balls and some careful use of fingernails or a plastic spatula.
    BTW does anyone know where I can get some pure acetone like the stuff used in chemistry labs? That stuff is supposed to be real cheap but I'm using nail-polish remover (70% acetone) which ain't cheap. But it does moisturise your hands and puts some shine and elasticity back in your skin.....
    1987 Peugeot 205 GTI S1
    1996 Jaguar XJR X300
    1991 Honda VT250 Spada
    1992 Peugeot 405 S (R.I.P. 31/07/2005)
    1000+ Posts Damien Gardner's Avatar
    Jan 2001
    Wendouree Vic. Aust
    2,436
    A fibreglass supplies store, will have good quality Acetone, here in Melb it's around $13 a Litre. Much cheaper than nail polish remover.
    Ps as your in Melb, the one i use most is Solid Solutions in Mc Kinnon off east boundary Rd, behind the Shell servo, the other id Daystar Chemicals in Dandenong over all a bit dearer than Solid Sol.
    Health and good fortune always,
    Damien.
    We rode on the winds of the rising storm,
    We ran to the sounds of thunder.
    We danced among the lightning bolts,
    and tore the R10's assfromunder.
    Robert Jordan & memyself&I
    1/48th Scale Alpine A310,
    N-scale 1/160th Renault & Citroen, Advert. Signs & Billboards
    8,923
    Acetone works well on glass but on car paint it's a bloody good paint stripper.
    If you just want to remove the glue stick with the turps.
    Using the hair dryer will get rid of the stripping but will still leave the residue of the glue there.
    Alan S
    Fellow Frogger! Reno17's Avatar
    Oct 2000
    Gold Coast
    690
    Hair dryier and prepwash, works a treat.
    1967 1135 R8 Gordini
    2012 BMW One Series M Coupe
    Fellow Frogger! PULS8R's Avatar
    Nov 2002
    Melbourne, VIC, Australia
    199
    Turps, ouch! I wouldn't put that anywhere near my car. The paint is crap and comes off easy enough as it is.
    Use a hairdryer or hot glue gun, just be careful with that. JUst use your fingernail to remove it, using other things is easy to scratch the paint. If some glue is left over get some Eucalyptus oil to remove it, smells great and works wonders on sticky stuff!
    Just don't be surprised if the paint is a different colour underneath.
    1995 306 XR
    Oct 2003
    Sydney, Australia
    568
    Well i'll take of of that into consideration..
    Cheers everyone
    Let you know how it all goes
    Mitch
    THE MAD PUGGA
    XTC
    XTC is offline
    Mar 2003
    Location Location Location
    8,566
    Steelo pad :>
    There is glue solvent removers ... unisolve is one .. not sure if they are safe on paint ... but they are safe on skin if that's anything to go by.
    - XTC206 -
    Now this is a .sig
    8,245
    Quote Originally Posted by XTC206
    Steelo pad :>
    - XTC206 -
    Some pretty good suggestions so far, I like the hammer and chissel and the Steelo pads
    Best results and safest are achieved using a hair dryer, the heat will soften the vinyl and the adhesive, should pull away in big strips, clean up with Prepsol/Prepwash to remove residual adhesive. There is a product that is used in the 'Sign writing' industry but for the life of me I can't remember the name of it, available from suppliers to the trade 'Spandex', 'Australian Sign Supplies', 'Supply One', or call in to any largish Sign Shop with a jam jar and a smile
    The only sticker left on your car should be our Aussiefrogs sticker
    08 C5 X7 HDi very Noir
    XTC
    XTC is offline
    Mar 2003
    8,566
    Quote Originally Posted by GreenBlood
    The only sticker left on your car should be our Aussiefrogs sticker Cheers Chris
    I think we can excuse a rego sticker
    - XTC206 -
    Now this is a .sig
    1000+ Posts dino's Avatar
    Nov 2002
    4,714
    chris is right.....i ve removed heaps of pinstripes....use a hair dryer to soften,,,,dab on some prepsol (PREPartory SOLvent hence the name)...KH makes a product called WAX and GREASE remover which is basiccally prepsol...available in most automotive shops.....
    remeber though...once u use prepsol (like most solvents)..it ll also remove any polish or wax on your car...SO u will need to repolish those areas affected....
    hair dryer and prepsol....industry standard
    cheers
    dino
    Oct 2003
    Sydney, Australia
    568
    Cheers. i'll get my mate to pick some up from his work...
    I should have asked some of the guys last night if they had any spare AF stickers. Oh well.. how would i be able to get my hands on some...
    THE MAD PUGGA
