removing norfolk island pine rosin
Results 1 to 25 of 26
    8,347
    Default removing norfolk island pine rosin
    I have a specific detailing problem which someone here might have found a solution to.
    How do you get dried on Norfolk Island Pine rosin off the paint??
    It is well dried on and prety thin, but stuburn as hell.
    I've tried soaking them with both paint shampoo and ct18, no joy.
    I tried wd40, no joy
    I tried water and a microfibre rag.. No joy. If too much pressure is used and a bit come off it will scrach the F out of the paint. Thats a big No joy if that happens.
    Car polish..... No joy,
    finger nail... joy but potential for paint damage on a nice car.
    SO what's the trick to getting this stuff off the paint??
    Paint is black metalic 2k.
    Jo
    Attached Thumbnails Attached Thumbnails removing norfolk island pine rosin-sap.jpg
    1000+ Posts Kim Luck's Avatar
    Melbourne, Aus.
    17,479
    Default Solvents
    As you suggest, Acetone (nail polish remover) probably won't do your paint a lot of good. You can try K+H Wax and Grease Remover or Prepsol.
    If you want to try something stronger in a small area under your car first you can have a go at Methyl Ethyl Ketone or my personal favourite, Toluene. If it doesn't come off with one of the foregoing, it's a repaint.
    8,347
    Quote Originally Posted by Kim Luck View Post
    They all sound a bit strong.
    I should add, the rosin is in the highest exposure bits of the car, not at all in area's that will blend in.
    Jo
    Melbourne, Aus.
    17,479
    I meant for you to try the solvent on a hidden area of the paint before slip slop slapping it onto an exposed area!
    You will need something strong to get the resin off, that's for sure.
    Melbourne, Aus.
    17,479
    My paint specialist says to use Eucalyptus oil.........
    JBN
    JBN is offline
    1000+ Posts JBN's Avatar
    8,005
    I would try grease and wax remover in the first instance. Its harmless to paint chemically. I use it quite often to remove tar from the car and then polish over the affected area.
    The only damage to paint would be if you put it on a rag and rubbed like hell, then the friction of the rag may scratch. Bug and tar remover used to work (badly) in that fashion.
    Being a French car, if left long enough the car will rust away from the paint, solving your problem.
    John
    8,347
    John
    Its a vy ss.
    The eucalyptus oil sounds like a worthy candidate.
    I'll give that a go.
    Jo
    1000+ Posts Gamma's Avatar
    Picton NSW
    1,412
    There are two things to try.
    Firstly:
    -try Kerosene
    -My fave....natural gum turpentine. (similar to the euc oil).
    As per other treatments, try out in a less conspicuous section of paint first.
    The Rosen will be as hard as hell, so patience is required and soaking for extended periods. Gentle rubbing of the raised parts with a cotton bud is best but if the car covered lash on recoating at regular intervals.
    /// 1986 SII 505 GTI
    2003 T5 307 HDI
    2013 LandRover90
    18,038
    Jo
    Jo,
    If the car is in two pack gun wash or acetone or thinners are OK for a quick dab. If it's acrylic then none are OK.
    Try a small section of original paint in the engine bay or under a guard with the chosen solvent - no colour on cloth = probably OK.
    Eucalyptus oil is a good solvent too, but can soften Acrylic if left on paint a long time.
    cheers
    Rob
    with apologies to Judy Grahn
    Member dunky's Avatar
    Nambucca Heads
    114
    As above. Eucalyptus oil or tea tree oil.
    It's how I roll...Brisbane
    32,709
    How about melting it off with boiling water?...........worth a shot.
    Melbourne, Aus.
    17,479
    Ever seen those funny white rings on a lacquered table and wonder how they got there?
    32,709
    I always thought they were from bonking on the furniture...
    Melbourne, Aus.
    17,479
    Which way up were you lying? I don't know, you young blokes....
    8,347
    I'd be guessing bent over forwards.
    Jo
    1000+ Posts okalford's Avatar
    Sep 2004
    10,859
    Agree Eucalyptus oil is a very good solvent. I find Lavender oil is even better. Whenever you use either always wash it down with lots of water and a cloth as soon as possible.
    '66 404 Wagon
    '78 504 Wagon
    '89 505 GTI S II Familiale
    1000+ Posts arunine's Avatar
    Port Denison WA 6525
    1,044
    I'll go with Gamma and pure turpentine or try Methylated Spirits.
    DS 21
    C4 HDI
    Piaggio Fly 125
    Blue Mountains Australia
    84
    Tolulene is a known carcinogen.
    Oct 2005
    Rome
    2,660
    Steel is heavier than aluminium.
    ​1997 BMW K1200RS
    IR655
    1,044
    Hou Long is a Chinaman.
    DS 21
    C4 HDI
    Piaggio Fly 125
    Melbourne, Aus.
    17,479
    Father knows LLoyd George
    32,709
    Quote Originally Posted by arunine View Post
    So is his cousin Sum Fing Wong
    Sydney - Chatswood
    2,023
    If all else fails, drive it to your mum's place, with that panel facing the flow of traffic as you turn in.
    Patrick
    Architect
    1991 Peugeot 605SVE (Written off 2007)
    1995 Peugeot 605SV (Bianca White) *SOLD*
    2007 Volvo XC70 Electric Silver (PJ-810)
    2009 Volvo XC60 T6 Teknik (Sapphire Black)
    2014 Volvo XC70 Luxury D5 Polestar (Ice White)
    2012 Mercedes Benz C250 (Alabandite)
    Past:
    1974 Triumph 2000Mk2, 1990 Renault 25TXE, 1986 Rover SD1, 1990 Peugeot 605SV, 1991 Peugeot 605SVE, 2001 Volvo XC70 and various Volvo 200-series
    296
    After you have removed the gunk you will need one of these:
    Attached Thumbnails Attached Thumbnails removing norfolk island pine rosin-csaw.gif
    Melbourne, Aus.
    17,479
    Is there anything left of the car after applying a dab of everything suggested or are you just left with the pine resin?
