i.c.e. question...
Results 1 to 8 of 8
    SMP addict pugjet's Avatar
    May 2002
    Enruoblem
    2,098
    i.c.e. question...
    hello,
    some of you audiophiles may be able to answer ma question.
    ive got a stacker in the boot.
    continually skips when the car is in motion or whenever i blink, pick ma nose, and even when i scratch ma big balls.
    it either skips or plays a cd for 2 seconds then a crackle and an error message on the head unit.
    obviously the ride in a 205 is harsh. its even harsher when its on 17s.
    come to think of it, it began skipping when the 17s were put on.
    is there sumtin i can do to make the stacker from skiping continously?
    would it make any difference if the stacker is inside the car as opposed to it being in the boot?
    i havent yet checked the connections, but say i have and it continues to do this... is there sumtin else i could do?
    senk que in advance cheers! ,
    pugjet blush
    current frogs :
    '94 s3 alpine 205GTi
    daily ding magnet: '98 1.8 16v citroen xsara
    previous frogs:
    88 S1 205GTi
    '95 306S16
    gimme corners. . .
    12,273
    i have a 12 year old kenwood stacker (it's huge ) in the boot of the 306 and it only skips if i hit a big bump
    it has been in many cars now and it used to be in the boot of a 504 i had that used to love dirt roads and it hardly ever skipped
    my only advice would be try and move it close to the centre of the car
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    1000+ Posts Damien Gardner's Avatar
    Jan 2001
    Wendouree Vic. Aust
    2,436
    Hey ma maaan.
    Da ansers tis soooooo ezy, take da skipin rop ofn da beeeech.
    Cheers mate
    Health and good fortune always,
    Damien.
    We rode on the winds of the rising storm,
    We ran to the sounds of thunder.
    We danced among the lightning bolts,
    and tore the R10's assfromunder.
    Robert Jordan & memyself&I
    1/48th Scale Alpine A310,
    N-scale 1/160th Renault & Citroen, Advert. Signs & Billboards
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    You could try mounting the stacker braket to the body of the boot with rubber exhaust mounts (the ones with a stud at each end and a hunk of rubber in the middle)....they cost about 2 bucks a pop and it worked well on my freinds car that skipped with low profile tyres....
    1000+ Posts CHRI'S16's Avatar
    Jun 2002
    3,298
    Most stackers skip because they aren't tied down tight enough.
    When i was installing, we found that if placed in the boot of a hatch it was necasry to drill and bolt it VERY securely.
    Also 99% of stackers have position switches for vertical/45'/horizontal mounting, check these on either side of the actual stacker and make sure they are correct.
    Perhaps you could also move it and place it were the lower shelf is in the dash?
    good luck - chris
    ... ptui!
    2000+ Brad's Avatar
    2,404
    Also, being located in the boot, it's over the rear wheels. If it was placed under the drivers seat, you would get less vertical movement when hitting bumps.
    Fellow Frogger! buzzedmi16's Avatar
    ACT
    142
    I had a mate that forgot to take out his travel bolts in his stacker... he put his seatblet on and the thing would skip... he fixed that real fast mallet
    Buzzed 405...Got a problem?
    May 2002
    Enruoblem
    2,098
    Damien Gardner:
    Hey ma maaan.
    Cheers mate
    whattup widdap g-thong homie roll_lau ?
    yeah checked the connections and everythang seems to be in order.
    im gonna look into moving the stacker from the boot to the interior of the car.
    ta y'all.
    current frogs :
    previous frogs:
    88 S1 205GTi
    '95 306S16
    gimme corners. . .
