306 Electrics
Results 1 to 25 of 42
Thread: 306 Electrics
    Feb 2003
    253
    306 Electrics
    Was wondering what problems N5 306s had with electrics if any? As I'm having some wierd things happening lately to the dash!
    Anyone know a competent auto elec?
    Feb 2003
    253
    Anyone?
    Feb 2001
    493
    on my ex 306, the only trouble i had with the dash was the dials not working. This was fixed by removing one of the fuses and refitting it. This seemed to reset the ECU as well.
    1000+ Posts CHRI'S16's Avatar
    Jun 2002
    3,298
    Well can you be more specific Kristian??...
    Most 306 owners know about their Sticking indicator stalk, that will keep the indicator clicking.
    Also there was a N3 recall for the clipping of some of the wirring harness, not 100% on this.
    Plus the A/C controler for the climate control has a little bit of a history...
    tell us more, be as blunt or as vauge as you need to. cheers chris
    ... ptui!
    Feb 2003
    253
    Will do.
    I noticed that when I accelerate from standing start that the engine & oil temp gauges waver/flicker. Ie; might be sitting on 90deg then drop to 70deg in an instant.
    Also, very rarely but has happended when I turn the ignition the speedo and tacho go nuts but the engine idle is not affected.
    Then there's the more common(I think) stereo flickering when the indicator is on or headlight flicker when accelerating.
    Whatever it is it seems to be causing all of this and more like hwy engine temp is at very beginning of temp gauge ie: below 70deg.
    A couple times the engine temp guage after switching of car went of the dial and dash literally (not from overheating just went the wrong way!)
    Any help much appreciated
    May 2001
    Sydney, NSW, Australia
    3,628
    Kristian,
    Given the problem is involving so many different components (on different circuits too) my bet is it's earthing.
    How old is your car again? It wouldn't surprise me if one of the following is not right
    -battery terminals - either loose, or have been taken off and re-fitted with a hammer (and not separated, put over the terminal and squeezed up then tightened). The other possibility is the terminals are just filthy.
    -earth strap - not done up tightly where it mounts onto the body (or could be at the -ve terminal as I mentioned above)
    -terminals for the dash instruments/stereo have somehow been tampered with (when installing a new stereo perhaps?) and might be not fully connected even though they look like they are.
    These sort of problems with instruments etc were common in our Cit XM. Fixing up the earthing fixed the problems.
    Hope that helps,
    Derek.
    12,256
    you may also want to get your alternator checked out as well
    if lights are flashing in your stereo while your blinkers are on it's a good sign that there isn't enough charge there but in saying this it could be as derek said a bad earth
    1 x '98 306 GTi6
    SMP addict pugjet's Avatar
    May 2002
    Enruoblem
    2,098
    hi kristian,
    the only electrical problem i had with my 306 is that it had a tendency to go in and out of power steering whilst parking.
    with respect to lights flickering you might want to take a look at your battery/terminals and/or alternator, but again as deka mentioned, could be bad earthing.
    current frogs :
    '94 s3 alpine 205GTi
    daily ding magnet: '98 1.8 16v citroen xsara
    previous frogs:
    88 S1 205GTi
    '95 306S16
    gimme corners. . .
    Feb 2003
    253
    Cheers All.
    Well the problem/s seem to be reccuring more often after getting a new battery. Forgot to mention that hard braking or cornering affect the temp guages so I'll check all the above and report back.
    Thanks again
    Feb 2003
    253
    Was just wondering what the normal engine and oil temp is for the 306 and would this be any different for the GTi6? Also, does the temp increase/decrease much or does it only increase say when giving it some quick bursts or on hot summer days?
    I have been told 90deg engine temp, sound right?
    May 2001
    3,628
    pugjet:
    pugjet,
    That's not electrical. It's a worn hydraulic ram which is worth about $300 +/- I think it cost me $400 to have it replaced. It is very very common on 306's with over 100 000km of predominately city driving. As such, I never ever use my power steering when the car is stationary as that is what causes the wear on the ram. Using the steering like you do in a non-power steering car when parking (move forwards super slowly while turning the wheel) takes a huge load off the power steering.
    Kristian,
    Hope that is the problem. Given the extra info about the battery it's sounding very likely
    Derek
    May 2001
    3,628
    Kristian:
    That's right for my car (2.0L 16v 100kw). Highway driving it comes down to 80-85, city driving it might go up to 90-95.
    Don't rely on that guage for 100% accurate temperatures however. It's more the position of it that is important.
    Derek
    Feb 2003
    253
    Never heard of a hydraulic ram before what is it and what's it's purpose. Ie how would it effect the electrics?
    My car has 83,500kms however, I bought it(with 65kms) off a guy that basically took it one suburb to work and back with the odd weekend cruise. So sorta fits into your explaination.
    Deka, does your's fluctuate much or is it very much constant?
    1000+ Posts tekkie's Avatar
    Jun 2002
    1,516
    The problem you are describing sounds like a faulty battery or bad earthing.
    On one of my previvious cars (Toyota T18 to be precise) the guages for water temp and... ther was onther one but i cant recall what, went stupid.
    That happened after a battery change. So I did a U turn and drove straight back to battery "specialist" where the consequent test revealed a dead battery plate.
    My only bug with the 306 is the digital odometer not showing whole numbers. Then after 5 minutes of sweet talking the car the numbers come back and all is fine.
    May 2001
    3,628
    Kristian:
    ooops sorry, I should have explained that better. The problem pugjet is experiencing is completely unrelated and is definately not electrical... so it has nothing to do with your problem. The power steering in a 306 is hydraulic, not electric. It is driven by a pump which is driven by a belt drive from the engine. The ram is mounted on the sub-frame of the car, right in the centre, just in front of the firewall. The pump is just near the headlight on the driver's side of the car.
    Don't worry about it in other words. I was just trying to help pugjet out - cos his problem is unrelated to yours.
    Derek
    p.s. if the new battery is faulty and they have to replace it, get a calcium plated one. I have had much better experiences with them than with anything else.
    Gordon, NSW
    4,527
    My former GTi6 would hover around 60-90 (more often around 70) for engine temp and 80-90 for oil temp.
    - Lincoln
    Feb 2003
    253
    Yeah mine hovers around 70 despite the fluctuations just doesn't seem to be normal though.
    I think my problems began before the new battery therefore that would rule out the battery being faulty
    Jun 2002
    3,298
    kristian, do this test for me, at night, turn on everything. radio, headlights, interior light, etc.
    Now watching the interior light, from idle rev the car slowly past idle, do any of the lights become brighter?? and when yo let go of the gas do they dim down again?
    Another thing to check is the -ve cable that goes from the -ve terminal on the battery to the body of the car. Its tricky to check, but if you can make sure it is very tight.
    Also try to prise back the carpet and under dash trim, on the drivers feet area, when you do this you are looking for Green/yellow cables that got to a bolt head in under the cables and back under side of the fuse box. Make sure this bolt is tight too.
    If in doubt see an auto electrician. Paul Vassalo, David Warner autom., or Esscargo/north shore rally sport, are who i recommend. cheers chris
    ... ptui!
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    Just a thought, but have you had the voltage regulator checked?
    Alan S
    Jun 2002
    3,298
    Alan S:
    Alan S
    .. you read my mind alan... hence why i asked him to do the light test that i wrote above. cheers chris
    ... ptui!
    Jun 2002
    3,298
    Alan S:
    Alan S
    ... ptui!
    10,769
    Alan S:
    Alan S
    Seems to have earth/charging issues/loose wire stamped all over this problem.
    We've never had a flicker from anything on our 306 in 8 years.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    Feb 2003
    253
    Thanks all again! Some great help and advice. Hopefully get a chance to check the above suggestions out and if not capable check with Paul as I've never been there and haven't heard a bad word. Is he pricey or reasonable?
    Gordon, NSW
    4,527
    reasonable, but ssshhh, Paul is becoming a secret wink
    - Lincoln
    Feb 2003
    253
    Ok Chris/Alan/Others
    I checked for the dimming slowly revving above idle. I didn't see any sign of brightning/diming of lights, although I did this in our underground carpark. How noticeable should the lights becoming brighter be? As when I've got the indicator on the brightness/dim 'thing' is clearly visible on the Pug in dash CD deck but not on the interior light or anything else
    I TRIED to check the -ve cable from the battery although almost impossible looking above the car into engine bay it seems this is bolted onto the engine block??? not the body of the car.
    Tonight I'll try and get underneath the carpet but in meantime any further suggestions much appreciated.
    Btw another quirk that happended on the weekend. When I turned my ignition off (with lights on) the warning sound was quite muffled/distorted than the normal sound. Does this fit the symptoms previously mentioned?
