Just a theoretical question about valves
    Fellow Frogger! two-oh-philic's Avatar
    Feb 2003
    Glen Waverley, Melbourne
    419
    Can anyone tell me why they don't have a single disc operating two valves.
    Ie: If a round disc the size of the bore had a sufficiently sized hole which went through say x degrees so that if it were made to rotate it would open up and close off different valves. Rather than something that needs to move up and down this would move in a circle.
    Has this already been tried? Or is it flawed somehow?
    205 GTi (S2 ) rolled
    '96 306XR "Sex" Black
    Banned Haakon's Avatar
    May 2002
    canberra...
    8,919
    Been done many times. One good example is a V8 with rotary valve heads used in WW2 german torpedoes. Was designed by Felix Wankel (inventor of the rotary engine who was required to work for the Nazis instead of being able to play with his own projects). The rotary valve head is very compact which was good for torpedoes. This engine was VERY powerful too, as they designed it to run at its limit and at extreme temperatures - because it didnt have to last very long.....
    6,655
    The main problem with the other forms of valve (like rotary valves or sleeve valves) is maintaining a seal. The poppet valve still seals as it wears because of its design, so it lasts a long time.
    2003 PEUGEOT 206 GTi
    May 2002
    canberra...
    8,919
    some links on the subject
    <a href="http://www.halfbakery.com/idea/Rotary_20Valve_20Engine" target="_blank">http://www.halfbakery.com/idea/Rotary_20Valve_20Engine</a>
    12,273
    there were a few rotary valve heads made back in the late 50's and early 60's
    i did a bit of work to one that bolted onto a holden grey motor quite a few years ago
    the bloke was using the motor only for drag racing
    sealing was a problem for them
    dunstan was one of the heads that were made
    i'd still like to work out a solenoid operated valve head for a pug as i think the options are endless for what ever output you are after
    i brought this up a while ago one here
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
