PSA HDi engines
Results 1 to 11 of 11
Thread: PSA HDi engines
    Fellow Frogger! BW205's Avatar
    Feb 2003
    Mostly Hong Kong and sometimes Brisbane
    513
    PSA HDi engines
    Guys,
    Apparently in Oz we only get the 90hp diesel 307 and in UK they also get choice of 110hp ones.
    What is the difference between these 2 engines. Beside the obvious power difference.
    Someone has told me that the 90hp one doesn't have a intercooler. Is that true??
    Billy peugeot_
    Stock '87 205 GTi
    Stock '98 306 GTi-6
    -Memories are good only if you don't have to deal with the past.-
    CitroŽn Tragic UFO's Avatar
    9,700
    BW205:
    Guys,
    Billy peugeot_
    Mechanically they are different - not sure of the details, but the real issue is that the diesel fuel in Aus is low grade and would screw up the high output engines - there would also be about an $8000 price difference in Aus.
    Until the fuel in Aus improves (which is happening) AND the market for diesel passenger vehicles increases (also slowly happening) we will have buckley's of seeing the 2.2l PSA HDi and their ilk here.
    May 2001
    Sydney, NSW, Australia
    3,626
    The 2.0L engine is available in a 110bhp version as well UFO
    BW205, UFO is correct... our diesel fuel is very poor quality (high levels of sulphur) and would damage the higher powered diesel engines.
    BP has already released their Ultra Low Sulphur diesel (50ppm) here: <a href="http://www.bp.com.au/products/fuels/bp_ecoultra/eco.asp" target="_blank">http://www.bp.com.au/products/fuels/bp_ecoultra/eco.asp</a> but the Australian Government has been rather slow to enforce low sulphur diesels... the requirement for these 'new' diesels is that they be on the market by 2006 snail I buy a fair bit of diesel and haven't seen a single bowser in Sydney branded with 'low sulphur' diesel. I did see a few at Victorian servos in February.
    Derek.
    Member Jon Wood's Avatar
    Feb 2002
    Swindon UK
    75
    Yes, the 110HP HDI engine has an Intercooler whereas the 90HP version does not.
    The 90Hp engine can easily be chipped to 110HP (still without an intecooler) and the 110HP engine there is a chip that gives 127HP!
    BX 1.7TD TZD 1993
    Berlingo Multispace 2.0 HDi 2004
    12,256
    the same as the engines used in the 306 and the 405
    the 405 has an intercooler where as the 306 doesn't
    apparently the sound deadening in the 306 compared to the 405 is quite noticable as well in the diesel variants
    1 x '98 306 GTi6
    Feb 2003
    513
    Thanks for the responses.
    I am thinking more and more about getting a diesel. But the only drawback is their acceleration.
    Is it hard and expensive to chip a diesel??
    I thought BP is bringing in the low sulphur diesel by end of the year in Queensland.
    Billy
    Stock '87 205 GTi
    Stock '98 306 GTi-6
    May 2002
    Berowra NSW
    4
    I have a 94 405srdt (180K kms) It is turbo intercooled. This motor is identical to that used in the 306xtdt of 95/96 (I regularly also travel in a 306xtdt)except for the mechacincal injection system.
    The 405 has a German Bosch system.
    The 306 has the British CAV Roto system. Both motors are turbo intercooled.
    As for accelleration, The first couple of metres are less than spectacular, bur when the turbo comes "on song" at about 2250rpm the the seat punches the spine and the car moves all the way through to about 4200rpm before peaking at 4900.(2800 rpm gives 110Km in 5th). I regularly top th fuel tank with about 50l after 700 - 800Km.
    Hill climbing is where these old diesels excell.
    The only way to judge them is to get your bum into the drivers seat and have a good drive of one or two or three. (have been known to leave v8s for dead on some of the F3 climbs when accellerating from about 100Kph).
    Ihave also driven a 307 Hdi. It is quicker of the mark but a lot smoother (neck brace not needed ) but produces the results.
    Try a PSA peugeot_ citroen_ Diesel, then Buy a PSA peugeot_ citroen_ Diesel
    mallet
    Philip 40405040306
    Feb 2003
    513
    cool....I have always been told that moving off in 1st gear in a diesel, a pushbike can beat it off the mark...but when snatching it into 2nd gear you leave everyone behind (and a lot of black smoke.....heheh)
    I just been to the FCD at UQ last weekend, and the Citroen being able to raise the suspension on harsh roads is good because the jobs involves me going to place where there is no sealed roads and middle of nowhere.....hmmm....I am tossed up between a 307 HDi or a C5 HDi (but C5 only in auto form)
    Billy
    Stock '87 205 GTi
    Stock '98 306 GTi-6
    XTC
    XTC is offline
    Mar 2003
    Location Location Location
    8,566
    What ever happen to the HDi engines that dropped a cylinder when cruising ? I thought this was a great idea, was it only VW that tried it ? Awesome way to save fuel.
    - XTC206 -
    Now this is a .sig
    May 2001
    3,626
    BW205:
    Billy,
    Did you actually ask about this? I'm not sure with the C5, but I know that with the XM you are NOT allowed to drive the vehicle above snails pace at any suspension setting other than the standard height. This means that you can raise the car to ease it through a big rut, or up and down gutters etc (we used to do this routinely with our XM, used to get it parked in at work here) but I know you were not supposed to drive at speed with it away from the normal setting.
    Do keep in mind that the C5 rides higher on rough roads at low speed than it does above 110km/hr (or is it 120km/hr) on hard surfaced flat roads.
    The biggest advantage of diesels for you would be range. 1300km + range in both those cars!
    Derek.
    nJm
    nJm is offline
    Guru nJm's Avatar
    Jan 2002
    Melbourne, Australia
    2,930
    I think the guy at the Melbourne FCD said the C5 will do 40km/h on maximum height?
    The actual Citroen website says:
    Above 110kmh Nose drops by 15mm and tail drops by 11mm, re-sets at 90kmh (where permitted).
    Poorly Surfaced Roads Nose and tail rises by 13mm up to 70kmh and then re-sets.
    Nick
    1983 Peugeot 505 GR
