mystery spark plugs for euro cars available
Results 1 to 25 of 27
    brisbane
    2,924
    does anybody know of a s/plug brand EYQUEM. they are made in france apparently and are for european cars. i may be able to get some bulk VERY cheap and then pass them on to aussiefrog people, but i wouldnt have a clue which car/motor could use them. they are eyquem 705 js type. any ideas??
    jr20516v
    Now:
    Exige SC [modded], 205 Si. 205 GTi , Megane R26 LY , Megane 225 [modded ]
    Previous: Honda EP3 Supercharged , 205 x34 [ including MI16 TURBO, 8v TURBO, CTI, 16V+TB's, 8V+TB's,] Fiat X1-9 X3, Beta coupes x5, Lancia Gamma coupe, GTI-R, Corvette C4, Fiero x5, Alpine GTA turbo, r5 GTT Dimma, 2cv ripple nose, Lotus Elise, 205 Dimma TT, Cliosport 172.x2, Clio rs 200
    rek
    rek is offline
    1000+ Posts rek's Avatar
    Melbourne, Vic
    1,388
    Eyquem are the automotive electronics division of Sagem (a French electronics company). You used to be able to get to a "spark plug selector" type page from the Sagem home page, but it seems to be broken now.
    Peter
    2008 Saab 9-3 1.9 TiD Sportcombi
    2011 Volvo C30 DRIVe 1.6D
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    It's a wonder that they aren't shown in your owners handbook as I think they are fitted standard to Cits, can't speak for the others.
    Only problem I can see is that for me, my CX will take a single contact plug whereas the BX 16V takes the 4 pole type and there is a different type for a 2200 to a 2400. I suppose it depends on whether you can pre-order them as I doubt you will be able to just buy a box of just one type.
    If you can get those 3/4 type plugs at the right price, I reckon you'll get more than a few excited
    A cross reference shouldn't be all that hard to come by. If Champion or any of those have a website, they may be available there.
    Alan S
    6,665
    My R12 came with a set of Eyquem plugs in the glovebox - from memory 704S. I've still got them in the shed - I'll have to check.
    Stuey
    2003 PEUGEOT 206 GTi
    brisbane
    2,924
    alan, i've tried owners handbooks, search engines and some other plug makers as a cross reference..still no info.all i found out was eyquem brand were supplied direct to peugeot. i'm not going to buy boxes of these if i cant find out what car can use them. i could then get stuck with them. i suppose i could always use them as sinkers for fishing!! any more help out there?
    jr20516v
    Now:
    8,923
    jr,
    For a BX 16V/Mi16 the plugs which mine had in it were FC 62 LS 3 (the "3" I would suspect standing for 3 terninal type)
    For a Citroen CX 2200 they recommend the 705 S
    For reasons best known to themselves, the plugs for a CX 2400 vary slightly to those on a 2200 As an example in other brands an AC 42FS on a CX2200 is replaced with an AC 43FS on a CX2400. I think that you'll find that specs wise they are so close that normal procedure is to use the same plug for both applications.
    If someone can find a handbook or service manual for a BX 16 and 19 series, we should be able to work out the equivalent Peugeots.
    Hope that helps shed some light. If I can get a hold of a conversion chart, I'll scan & post it.
    Alan S
    16,748
    Hi Guys,
    strange there different?? You see I bought a box of NGK plugs in to suit the old ID19. The plugs turned out to be identical for ID19 - DS23 inj, CX2000 - CX2500... ie: all the same. Just through some of them into the CX and replaced its exhaust flex & both mufflers. The change in the way the car drives in un-beleivable. The torque down low has increased 10fold. And it's not trying to choke me to death everytime I drive it anymore.
    There got to be cross reference charts for the plugs your after on the net somewhere??
    Shane L
    [ 16 November 2001: Message edited by: DoubleChevron ]
    6,665
    JR,
    My original R12 owners manual specifies the "Eyquem Renault 705S" for the low compression version of the 12. They must've done the OEM plugs or a least some of them.
    Stuey
    [ 16 November 2001: Message edited by: Stuey ]
    Fellow Frogger! ipb205's Avatar
    Wright ACT
    585
    Yeah they are hardly a mystery brand - my mechanic seems to have boxes of them and uses them in Pugs and Renos all the time.
    Alpine Motors in Canberra will be able to give you specifics of the cross referencing if required for a particular car.
    ipb
    May 2001
    Sydney, NSW, Australia
    3,652
    Speaking of spark plugs Wongy at AutoFrance (Artarmon) told me to put Beru plugs in my 306... I got them but haven't even taken them out of the box yet. I think they're 3 or 4 electrode? Apparently they're the same as what goes in the XM now. I know the XM had Eyquem in it when we bought it. I'll let you know anyway.
    Derek
    2000+ Brad's Avatar
    2,404
    Would these brands discussed have any notable difference to your standard NGK's or Champion's?
    brisbane
    2,924
    yes fellas, i know eyquem plugs go into alot of cars particuly french ones... thats why i'm asking for help! but which ones?? as u know if the wrong heat range is put in a car it will run like a hairy dog. if aussie frog members can help out on this one it might benefit us all. we are talking around 60 cents each to u guys. can anybody cross reference out there..i've tried all avenues. come on all u detectives out there[before they get sold on me]
    jr20516v
    Now:
    May 2001
    3,652
    Hi,
    Well just changed the plugs on the 306XR (1.8L)
    The old ones were Eyquem RFC52LS so my guess is the 705 JS wouldn't be suitable for a 306?
    The new ones I put in are Beru UltraX UXF79. They are 4 electrode and the car seems much more responsive but that was only on a drive around the block. They were $10.40 each.
    See ya,
    Derek
    8,923
    Rightyo,
    Just got back from the local SupaCheap and you don't wanna know the stories so that I could get my hand on a plug chart. Got in & got out quickly so I didn't push the luck; here's what I found out.
    The plug recommended for a CX Citroen was an NGK BP6HS
    Now they didn't have a comparison chart for our Eyquem brand but I have found in the service manual that the CX Citroens take a 705S and these plugs of jr's are shown as a "JS" so I don't know it therte is any difference. Maybe someone can find out.
    If they do turn out to be the same as the NGK BP6HS, then they are compatible with:
    ALL CX's
    All D's
    Renault R-12 and Virage
    Renault R-15.
    If they are close enough to be good enough, to a BP6ES or BP6EFS in NGK, then they will be suitable for the Peugeot 504 & 505 as well as a couple more of the Renault range.
    Hope this sheds some light. I can also post a website but it is in Danish but apparently it is understandable and shows these brand as well as others as individual as well as 4 pack in parts numbers.
    Here is the message I got from a guy in Denmark; hopefully you are a bit more computer literate than I and can get it to a readable size.
    Alan,
    It appears that the info we need is there.You do not HAVE to mail me, but of course use the Biltema site :
    Click "Katalog" then the yellow section "Bilreservdelar". Then choose reserv_2.pdf for download. This section contains the spark plugs tables.
    It's all in Swedish language as is the company, but price tags are converted to danish currency.
    To compare prices, just divide by 12, then you get accurate prices in UKŁ.
    C U
    Link: http://www.biltema.dk
    Here's hoping this solves it.
    A very
    Alan S
    7,552
    Eyquem FC62LS2 are std. fitment in Mi16 XU9J4. Not sure about XU9J4Z. 52's are one step hotter, so if they equal 705, they should be fine in lower CR engines.
    8,923
    DAVID C!!!
    Can you shed any light on this ?????
    Alan S
    Feb 2001
    Romsey, Victoria, Australia
    4,904
    Yes Alan I've been reading this, to me I've never noticed any real difference in plug brands, I'm running Eyquem in the MI16 at the moment (just to try them out) I have some customers who insist on Eyquem other who don't care, my brother is running NGK in his BX 16V and has done something close to 100,000 km so for and he uses the theory that if it aint broke don't fix it. I stock NGK and use BP6HS in D, CX and R12's, BP6EFS in Fuegos, 505s ect. I don't use champion because they had a reputation of needing to buy 8 to get 4 good ones. I know the dealers will shudder at the thought of using anything else beside Eyquem and I've heard many people agree, especially with 16V engines and for that reason only we fit them, but really I've never seen any evidence they are any better than NGK, I think my brothers BX is proof of this.
    Having said all this, the main reason people chose NGK is price and availability, if someone can overcome these two important problems then by all means stick to what the dealers say.
    I'm pretty sure I've got the correct plug types at work, I'll look it up tomorrow.
    David.
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    frenchconnect@bigpond.com
    Wright ACT
    585
    check out <a href="http://members.optusnet.com.au/~nilsbown/oilfuelspark.htm" target="_blank">http://members.optusnet.com.au/~nilsbown/oilfuelspark.htm</a>
    then follow the link to the Sagem website and check out the entire range on line...
    ipb
    8,923
    jr,
    What's the latest on these plugs?
    Alan S <img src="confused.gif" border="0">
    brisbane
    2,924
    thanx ian, i tried but to no avail!! the cross reference search chart was reverse about face if u can follow what i mean. i had to place in the opposition type spark plug no. and out would spit the equem no. for it. i tried it in reverse..no go! i punched in peugeot mi16 and got this as a reply... no match. the only way to do it would be to get every body to put in their plug no and try and jag it. any other ideas?? cheers
    jr20516v
    Now:
    Wright ACT
    585
    go! i punched in peugeot mi16 and got this as a reply... no match. the only way to do it would be to get every body to put in their plug no and try and jag it. any other ideas?? cheers[/QB][/QUOTE]
    Try Peugeot and then 405 in the model section and all 405's come up. I did this for the 205 and got every model 205 that was ever made.
    good luck
    SYDNEY
    22
    eyquem are the standard genuine peugeot plug
    the part # for plugs for your mi is 59625f
    this also can be used in all 205s 8v
    306 8vs& 16vs
    seeya
    SYDNEY
    22
    also jr
    is your rear spoiler from autofive???
    brisbane
    2,924
    no josh, its from ecosse..from the french co. auto tuning. big $$$ too but dont tell my wife, she'd kill me if she found out what i paid for it.
    jr20516v
    Now:
    Dec 2002
    119
    Acutally FC62LS3 are standard fitment only to XU9J4 (D6C tagged motor), even though many people find them in their XU9J4Z (DFW tagged motor).
    THE FACTS:
    RFC58LS3 are recommended by Eyquem for XU9J4Z (DFW tagged motor). They are what Peugeot will sell you - this is the only Eyquem spark plug listed for 1.9 Mi16 (DFW) in Australia.
