4x4 brakes
Results 1 to 20 of 20
Thread: 4x4 brakes
    2000+ Brad's Avatar
    2,404
    4x4 brakes
    Just a short one...why do most, if not all 4x4's have large diameter brakes at the rear?
    9,223
    They have a fair bit of weight on the rear wheels, generally... and they would be single leading shoe brakes.
    Are they also fairly narrow?
    2000+ Brad's Avatar
    2,404
    Yeah, from what I have noticed they are. Especially RAV4's.
    nJm
    nJm is offline
    Guru nJm's Avatar
    Jan 2002
    Melbourne, Australia
    2,930
    To look better through the fine spoked 20" alloys they all seem to have these days
    Nick
    1983 Peugeot 505 GR
    Aug 2002
    1,290
    Mine has the same size as the front, slightly smaller swept area due to the stupid handbrake setup in the disk. Fair sized pads and single pot calipers. Dont forget that when reversing down steep, rutted hills the rear brakes do the work. Fronts are of little use when the track is shaly and steep and wet and you are going backwards.
    Neil
    '94 405 SRBT
    '82 CX 2400 Pallas 5spd
    '76 CX Super
    '05 WL Statesman
    '92 HZJ80 Landcruiser
    2000+ Brad's Avatar
    2,404
    As a matter if interest, the new BMW M cars have larger rear brakes than fronts. Apparently it's due to the traction control system, which activates the rear brakes when traction is lost, can overpower lesser setup's.
    Sense Pug307's Avatar
    Australia
    4,355
    406 does as well.
    IIRC, 283mm at the front (same size as the 206 GTi180, 306 GTi-6, 307) 290mm at the rear.
    Peugeot 307 XS 1.6
    Rendezvous Adelaide 2005
    1000+ Posts CHRI'S16's Avatar
    Jun 2002
    3,298
    I noticed this too, but one thing that is considerably smaller on the rears is the contact surface area...
    i think its got to do with the towing abilities of the cars/4wd. The inertia in a 4wd is huge and moving itself and a trailer would require big rear axles to transfer the power to those huge wheels. bigger axles would need to be cleared by bigger diameter disks?? hows this theory sound guys?... just a thougt. - chris
    ... ptui!
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    It is simply a matter of cost.
    It is cheaper to manufacture rear discs using an internal drum handbrake setup (I dont know why). The drum on a 4wd would have to be of a reasonable size to actually hold the 2.5 tonnes that alot of 4x4's weigh. The bigger the internal handbrake drum, the bigger the disk diameter...
    Aug 2002
    1,290
    Bollocks internal drum handbrakes are a pandering to the toorak tractor set who cant use a proper drive shaft mounted transmission brake. The inner drum handbrake on the 80 series landcruiser must be kept in perfect adjustment to be of any use whatso ever.
    Neil
    '94 405 SRBT
    '76 CX Super
    '05 WL Statesman
    16,702
    Hi Guys,
    just look at what a Cruiser can tow, about 3+ tons (Cruiserman??). Man if I had to tow something heavy they'd be at the top of my shopping list (right next to a light/mediam rigid truck --well they are the same thing).
    Has anyone here actualy looked at the specs for the new HDi turbo deisel cruisers eek! eek! Man the torque those thing create is downright stunning !! With that sort of power and towing capability I'd be downright shocked if they didn't have mamoth sized brakes under 'em wink
    Yes I know the middle aged women will never use the capabilities... but still... If I had something really heavy to move, maybe some mother with 2 kids will allow me to borrow her barge for a couple of hours ...
    9,223
    Originally posted by CHRI'S16
    <strong>I..... think its got to do with the towing abilities of the cars/4wd. The inertia in a 4wd is huge and moving itself and a trailer would require big rear axles to transfer the power to those huge wheels. bigger axles would need to be cleared by bigger diameter disks?? hows this theory sound guys?... just a thought. - chris
    Even on large trucks, the axles don't get to be that big...
    Not a valid suggestion, really.
    Fellow Frogger! seesully's Avatar
    Sep 2003
    Middle Park, Melbourne
    260
    Hi,
    A larger rear disc, in simple terms, equals greater stopping power.
    You will also find that alot of newer 4x4's and cars have EBD (Electronic Brakeforce Distribution) or the equivalent. Theses systems allow there to be an even amount of braking force applied to the front and rear wheels regardless of whether it is empty or fully loaded. In the instances of when the vehicle is fully loaded, a larger rear disc or drum is required to allow for appropriate stopping power.
    Les hurlements de lion.
    504 GL (gone)
    205 GTI Classic (gone)
    505 STI (gone)
    I can feel a GTI 180 coming on!
    Member Freddie's Avatar
    Apr 2002
    Torquay, Victoria
    72
    Looking at most front brakes these days on larger cars there appears to be limited space to increase their size by much so its logical for greater braking power to look elsewhere - hence rear disks
    Guru davemcbean's Avatar
    Apr 2001
    Camden NSW & Selwyn NZ
    2,342
    mistareno:
    It is cheaper to manufacture rear discs using an internal drum handbrake setup (I dont know why). ...
    Internal drum cable operated handbrakes work better than caliper cable operated handbrakes. Anyone who has done any mechanical engineering studies will know that it's just a matter of mechanical advantage. It's very hard to make a cable handbrake work well with a caliper and still get acceptable handbrake lever travel and reliability of adjustment. Percentage-wise there's alot more caliper handbrakes out there which are out of wack and not working properly anymore than there is amongst the drum type.
    Dave
    <small>[ 19 September 2003, 05:18 PM: Message edited by: davemcbean ]</small>
    NZ Fleet
    1976 504 Ti
    1984 205 GT twin carb
    1991 205 SI 1.6GTI motor
    1994 106 Xsi
    1996 Mondeo V6
    Aus Fleet
    1955 203C
    Fellow Frogger! BigH's Avatar
    Oct 2002
    206
    Have you checked out the torque figures on the new VW Taureg 4X4 V10 twin turbo diesel? 750 Nm. They reckon you can use it to tow cities.
    Hank.
    9,223
    Originally posted by Freddie
    <strong>Looking at most front brakes these days on larger cars there appears to be limited space to increase their size by much so its logical for greater braking power to look elsewhere - hence rear disks
    Not really...
    You can only apply so much braking to the rear before you lock the wheels and make it very hard to retain control.
    Brake balance is still required...
    Australia
    4,355
    Ray Bell:
    Not really...
    That's why there's EBD - brake force distribution as used in the PSA cars apportions the maximum safely possible braking effort to the rear wheels, and between the left & right rear wheel.
    Anyone noticed how wheels are getting bigger these days - brake discs are a key reason - that's why the 307 is equipped with 15" wheels as a minimum (& all cars, whether it be a tiddler 1.4 or a 2.0 HDi have 283mm front discs).
    As cars become heavier, they need more powerful brakes. Cars really are heavier these days.
    Anyone noticed how powerful small cars are becoming. Base engine in the Mazda 3 has 104kW, heck the larger 406 doesn't even have that! Again, it's related to weight - power gains have largely erased any progress in fuel consumption.
    Peugeot 307 XS 1.6
    12,278
    the rears maybe larger in diameter but the pad surface area is still fairly small compared to the fronts
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    1000+ Posts tekkie's Avatar
    Jun 2002
    1,516
    I think,
    larger rotors dissipate (spelling?) heat better.
    As someone already pointed out 2tons+ of the wagon + 1.5tons of a trailer equals a lot of heat down the Victoria Pass or any number of steep hills.
    Making the rotors large (even when the pads are small) it saves the need to cross drill or ventilate the rear brakes as the safety needs are met to some or other Australian standard.
    my 2_cents worth
