ICE Amplifier
Results 1 to 3 of 3
Thread: ICE Amplifier
    Fellow Frogger! MR206's Avatar
    Apr 2002
    Sydney Australia
    331
    ICE Amplifier
    i got a amp....everything is hooked up fine...and tested it all out...BUT only one channel is not working....so i hav one 6x9 instead of two working....any1 hav any idea wat would be the best thing to do...is it repairable?
    2002 China Blue Peugeot XT
    Canberra Raiders #1 Season Ticket Holder
    2000+ Brad's Avatar
    2,404
    Do you know for sure that it is the channel on the amp not working? Have you swapped the inputs around? If the same channel continues to not work, then you know it is down stream from the input. Then swap speaker wires, if it is still the same channel not working, then you know it is not the speaker wiring or speaker itself. Does the amp have multiple fuses? Some amps have a blade fuse for each channel, check these. Check all the crossovers, gains and input selectors if there are any. Other than that, sounds like a stuffed amp.
    Apr 2002
    Sydney Australia
    331
    Phasis:
    done all of that...swapped speaker wires...checked fuses.... everything on the amp works fine...except that single channel...i dont wanna spend money on a new ampppp!! cry cry
