Welcome back AF
Results 1 to 8 of 8
Thread: Welcome back AF
    Dec 2004
    166
    Default Overhaul cost of Bx16v G/Box?
    Assuming the g/box will only need new synchros and bearings and labour at around $50/hr, what would I be up for to remove the box, replace the above parts and refit to car?
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    How long's a piece of string?
    It seems the "art" of reconditioning gearboxes has been long lost. Not all that many years ago, mechanics did them as just another job, but these days they all want to talk replacement boxes and seem to go on with more bloody dramas than "Days of our drearies" if it's suggested they work on the innards of one.
    I can see a day in taking in & out from go to ready to drive away, so say 8 hours there.
    Actual work I've never seen anyone spend more than 4 hours stripping, cleaning, stripping, fitting new parts and reassembling, so at worst say 12 hours.
    Based on that, I suppose $600 labour all up would be maximum.
    These BE3 gearboxes would have to be one of the most bombproof gearboxes I have ever struck so be real careful that you're not helping someone live in a manner to which he has grown accustomed by diving in and getting the gearbox 'overhauled' as they rarely have these kinds of failures unless of course your car has done mega miles. I knew of one in the UK that had a badly worn selector fork at 575,000 miles but no other problems.
    Common causes of the problems you have mentioned are bent or cracked clutch pedal causing the clutch to not properly disengage and to show symptoms of sticky synchros, clutch cable on the way out (particularly fraying at the bend where it passes through the tube at the firewall,) cracking or flexing at the lever where the cable connects at the bellhousing and of course the most common of all, insufficient or incorrect oil used. Anything above 80 grade and anything but mineral seems to catch a lot out regardless of what they have been told by makers or anyone else.
    As too many of these guys send the boxes off for another party to have a go at, I've found usually prices in the region of $2500 for the job isn't uncommon and I'd suggest you take a real close look at the possible causes I've detailed above, as failure in these boxes going on the overseas experience with higher mileages, is more the exception than the rule.
    Alan S
    Dec 2004
    166
    As far as I understand the gearchanges cannot be rushed especially 1st to 2nd or else it crunches.
    It's good to know these boxes are built tough though, so maybe it's not as bad as one thinks, at least I hope so!
    16,702
    Betcha the clutch is dragging slightly... Does it disengage right on the floor ?? I found unless I had mine adjusted right to the top of the clutch pedal it'd slightly crunch the 1st-2nd change... The problem being somewhere in the clutch mechanism, *NOT* the gearbox. Someday I might whip the motor out of that car and see what the problem was. I woudln't be surprised if it's something simple like the the pin through the throwout fork disitigrating ... or something simple like that. The clutch still had plenty of bite when it got parked up (it just couldn't be dis-engaged).
    1000+ Posts dogboy's Avatar
    melbourne,victoria,australia
    1,374
    I've seen that 16 valve when I popped in to french garage to check up on the progress on my BX19....seemed nice...bit of damage to front bumper but not too bad and car speedo showed only 140,000!!....There was a Peugeot 205 guy there who seemed quite keen to buy it...guess what for!!!!
    There goes another one!!
    Rev. Dogboy
    1969 DS21 Pallas BVH with leather
    1970 Renault 16TS
    1967 Honda S800 cabrio
    Citroen 1966 ID Safari (with 23 running gear)
    1975 VW Kombi poptop
    Porsche Boxster S manual
    1988 Vespa PX200E
    8,923
    Quote Originally Posted by dogboy
    ....................and you didn't run over him!!
    Alan S
    Dec 2004
    166
    Don't tell me he wants to use the Bx16v engine/gearbox in his little shopping trolley??
    WTF!!!
    That's just not right, no way!!
    1,374
    sooooo tempted Alan!!! Not a bad 16 valve by any stretch...I think Macca's 16 valve was great value at $5k but that took a while to sell so this one at $3500
    may indeed end up being wrecked...at least you 16 valve guys out there will have a source of spares
    If I could sell my BX19 and appease SWMO I'd own it !!!
    Rev. Dogboy
    1970 Renault 16TS
    1988 Vespa PX200E
