Rattling Cat? Change it now!
Results 1 to 11 of 11
    1000+ Posts Haakon's Avatar
    May 2002
    canberra...
    8,752
    Default Rattling Cat? Change it now!
    That will learn me... Catalytic convertwer has been rattling away for a while now, and i have been ignoring it on account of being too poor to get it replaced
    Cruising down the freeway towards home, and the power drops off badly, along with a nasty hissing noise under "power". Getting worse quickly. Finally get to an off ramp, and it dies at the lights. Much cranking gets it going - just. Not good
    Manage to get it onto a side street and all is not well. A handy piece of wood I find is used to bash the buggery out of the cat, and it fires up again and runs perfectly, and then I manage to get it home slowly.
    It would seem a bit of the disintergrating porcilen matrix of the cat had wedged itself firmly in the outlet of the cat and had blocked the exhaust fairly comprehensivly, and the hissing was gas being forced past the flexible flange joint. I had put the drop in power over the last few days down to a dud load of fuel, but i guess it was blocked exhaust after all...
    I at least know what I am doing Saturday - pulling the cat off and bashing the bits out
    monbulk
    645
    Default Dead Cat
    My 405 runs sans cat. It does have a slightly distinctive hollow sounding exhaust note, but all the power and economy is back. Mine was destroyed by a head gasket blowing and the contaminants destroying the porous ceramic. The bits then turned sideways and strangled the motor. It's pretty disconcerting when it happens. You'll have to remove all the ceramic pieces. And replacing the cat is a legal requirement......
    (apparently)
    Fellow Frogger! Filldebin's Avatar
    Sep 2003
    Sweden
    177
    You blokes are so lucky not to have emission checks every year. If it doesn't work you just have to buy a new catalyctic section. Fortunately, there are cheaper 'standard' ones available now.
    Phil
    May 2002
    canberra...
    8,752
    Brand new stainless high flow cat will set me back $300. But at the moment a trip to the dentist is more pressing
    So for the moment I will have to run sans cat, but will get it replaced as soon as I can.
    Fellow Frogger! Ren25's Avatar
    Dec 2002
    Perth
    299
    "Put a Crowbar thru it" (advice from my car man)
    Mike
    Armageddon was yesterday
    Today we have a problem
    2000 406 Hdi X 3
    2003 307 Hdi
    May 2002
    canberra...
    8,752
    Mutter mutter... Under the car stuffing around with exhausts is NOT how I wanted to spend saturday morning . But all done now - so quite, rattle free and feel the power!
    1000+ Posts Dave's Avatar
    Apr 2001
    1,340
    phwarrr as much extra power as you got from the AF sticker???
    Dave
    1000+ Posts Shobbz's Avatar
    Brisbane, Australia
    1,284
    Quote Originally Posted by Dave
    Dave
    I have heard with higher fuel prices the power has actually increased.
    shobbz
    Previous
    2005 407 ST Exec
    1975 504 GL
    Jul 2004
    803
    Quote Originally Posted by Shobbz
    shobbz
    Lucky I have two!
    2006 Peugeot 206 Xt
    1991 Toyota mx83 grande 1jzgte
    May 2002
    canberra...
    8,752
    Power is up even more after I disconnected the battery to reset the ECU. It had a bit of flat spot at around 3000 rpm and is all gone now. Guess taking off the O2 sensor upset the computer
    1000+ Posts mr bern's Avatar
    Feb 2003
    Melbourne (or touring)
    1,152
    Quote Originally Posted by Haakon
    I don't know how much credence to give this, but I do know that the penalties for disabling a cat are pretty severe, and according to what I was told, a vehicle without a cat sticks out like the proverbials to a monitoring station, even if it's buried in the middle of very heavy passing traffic. Might be something to do with how it's supposedly just about impossible to suffocate yourself with a (properly-regulated) car exhaust these days ...
    MY15 208GTi
    previously:
    MY10 Sportium HDi6 and 1.6L auto
    MY99 206GTi
    MY96 306XSi auto
    MY02 Clio 1.4L auto
    1ére grenouille:
    MY5? Simca Aronde 90A
    QUICK! MORE BREAD, MORE CIRCUSES!!
