Oils aint oils ?
Results 1 to 14 of 14
    XTC
    XTC is offline
    Mar 2003
    Location Location Location
    8,566
    Default Oils aint oils ?
    Which one to use when ?
    Mobil 1 0W-40
    Mobil 1 10W30
    Mobil 1 5W-50
    Mobil 1 15W-50
    Price range from $60 to $90
    - xTc -
    Now this is a .sig
    1000+ Posts Fordman's Avatar
    May 2004
    Perth/West Australia
    1,334
    Your owners manual should give you the recommended viscosity range for your engine. It may be dependent on the ambient temperatures where and when you are driving.
    Renault recommend 15w-50 for the Scenic 2.0 litre which in my opinion is a good range for Australian conditions.
    However if I lived in Canberra for example (cold winters) I would probably use 5w-50.
    You may already know this but for general basic info for anyone reading this:
    The lower the number, the "thinner" the oil, and vice versa.
    In cold temperatures, or when the engine is first started, the thinner oil can better move around the engine while the engine is cold (eg 5w,10w,15w)
    But in hotter temps (and when the engine warms up) the low viscosity oil would get too "thin" and not lubricate the engine, so you need a higher viscosity (eg 30w,40w,50w)(Real oil!).
    Multigrade oils combine the properties of a range of viscosities. Eg, 10w-50 means that when cold the oil acts like 10w and when hot it acts like 50w.
    Mobil 1 is fully synthetic so they can obtain a very wide range of viscosities. You won't find 5w-50 in a non-synthetic oil.
    If I was doing lots of highway driving I would definitely use a 50w upper level.
    I think the lower level depends on the engine design and the ambient temp.
    Hope this is of some assistance.
    Fellow Frogger! DejaVu's Avatar
    Sep 2004
    Croydon, Melbourne
    693
    also, i was getting some noise from the engine, so i moved to Pennzoil 5W-50 full synthetic, and this eliminated alot of the noise and i felt the engine liked this oil much much better.
    2013 Megane RS 265 Trophy
    Gordon, NSW
    4,527
    Quote Originally Posted by XTC
    Mobil 1 0W-40
    Mobil 1 10W30
    Mobil 1 5W-50
    Mobil 1 15W-50
    - xTc -
    In your car, I'd be using 5w-50, but I'd be recommending BP Visco in 5W-40 over 5W-50.
    - Lincoln
    XTC
    XTC is offline
    Mar 2003
    8,566
    Quote Originally Posted by GTI124
    mmmmmm currently it's using Mob1 5W-50W. I'm about to do a self oil change this week and was just looking at oil options. Hence the question.
    Now this is a .sig
    Sep 2003
    North Parramatta
    3,981
    I'd probably be using 5w40 too - although there is nothing wrong with Mobil 1. Some people carry on like it is the devil incarnate.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    9,223
    Nothing wrong with it? Doesn't it come from dirt?
    I'm sure Brocky was on TV revealing all...
    Gordon, NSW
    4,527
    Quote Originally Posted by SLC206
    Which is why I tend to recommend the readily available BP products which do well in oil tests I've seen. They're as good and cheaper.
    Nothing overly wrong with Mobil 1 5w-50, I just think the range of that oil can only have a compromising affect.
    - Lincoln
    May 2004
    1,334
    If my memory serves me correctly, Brocky was advertising Mobil 1 as being better than mineral oils because "they" (mineral oils) came from the dirt. ("Would you use an oil that comes from the dirt??" - wasn't that it?).
    Mobil 1 being fully synthetic was apparently all clean & healthy!
    Personally I use Shell Helix Plus 15w-50 (semi-synth) at about $25.00 per 5 litres as I went off Mobil 1 when it jumped to $60 for the same amount. It also seems to be right for every car in the family including the LPG one.
    BTW, Ray, I don't take much notice of the current Shell ads which liken clean engine oil to filling up your engine with beautiful cleansing sea-water or something equally stupid! Sounds worse than Mobil dirt!
    Cheers.
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    Have a read, make your own informed decision.
    http://www.chris-longhurst.com/carbi...oil_bible.html
    Alan S
    Aug 2003
    Perth
    918
    Default Thanks Allan
    That was very imformative.
    Graelin
    9,223
    Yeah, that's a bit weird...
    My point was, however, that it's not only 'mineral' oils that come from dirt... and what's a 'mineral' oil anyway?
    Shale oil would be mineral, but your everyday Saudi crude, we're told, is decomposed dinosaur. That's hardly mineral!
    So what would 'synthetic' oil be made from anyway? There's very little that doesn't come from dirt, after all, and even if it's from some vegetation, that grows in dirt all the same.
    For my money, Brocky got his hand dirty for nothing...
    Fellow Frogger! whitegoshawk's Avatar
    Oct 2003
    Sydney (sometimes)
    309
    I suppoes its like 'organic' vegetables in the supermarket. I am looking to buy some 'inorganic' vegetables to compare what they taste like...
    Was that before or after the Energy Polariser?
    whitegoshawk (pretend butter comes from pretend cows)
    "You see, wire telegraph is a kind of a very, very long cat. You pull his tail in New York and his head is meowing in Los Angeles... Radio operates exactly the same way: you send signals here, they receive them there. The only difference is that there is no cat." - Albert Einstein
    Xantia Activa CT - Chock full of upsy-downsy goodness!
    Sep 2003
    North Parramatta
    3,981
    Quote Originally Posted by whitegoshawk
    I'm with you, whitegoshawk.
    For years I've been looking for inorganic veggies, but I just can't seem to find any
    Simon
