Humid +coil packs
Results 1 to 7 of 7
    Aug 2003
    Perth
    925
    Default Humid +coil packs
    My brothers Clio went to visit the workshop agai under warranty. This time the friendly man in a tow truck had to take it as it failed to progress under its own steam.
    Dealer under warranry has replaced all of the coil packs, the stated reason for failure is the Humid conditions in Perth at the moment.
    Graelin
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    If that's the true cause, then you would have to think they had hair cracks in them to begin with.
    Alan S
    Aug 2003
    Perth
    925
    Default Alan
    Yes thanks, I was kind of wondering why all my coil packs had not gone out as well!! I live only 8km away from him.
    Graelin
    8,923
    I have a Johnson 70HP outboard that has a similar coil pack system and a few years ago we had a few running issues with it. An old outboard mechanic just took one look at it, pulled the coil pack off and resealed the many hair cracks in the epoxy with some kind of resin and we've lived happily ever after.
    To my way of thinking, any coil is a sealed arrangement and can't be affected by moisture unless the moisture's getting into the actual coil section itself. Overseas with the rain and snow it would be every car ever made in strife if just humidity/moisture made them stop.
    Alan S
    Sep 2003
    North Parramatta
    4,003
    Quote Originally Posted by Graelin
    Graelin
    Humid conditions in Perth? Lucky the car is not over in the eastern states then! I assume it has one coil pack per cylinder. All 4 coil packs is a worry.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Aug 2003
    Perth
    925
    Default All four coil packs
    Not all four went but enough to stop it progressing it was still running but only just. RAC attended and it had to be towed to dealer.
    They say they replaced all four coil packs. Thia is a 1.4 auto so I guess that with two cylinders down doesnt leave a lot of power in reserve.
    Graelin
    Oct 2003
    624
    Graelin
    Just had the same thing happen on my 02 1.4 man. Was only running on two cylinders, still drivable, shook like blender. All 4 coil packs replaced underwarranty.
    1 Month prior, TDC sensor packed it in.
    NSW.
